Old 11-26-2023, 04:12 AM
Hellrow Hellrow is offline
Default Mute channel when recording in headphones
Hi!
New member here.
I got a strange thing in Protools artist.
When I record for an example guitars I wanna mute the channel so I just hear the speaker and not the sound in headphones.
My problem:
Even if I mute theres still sound in headphones.
If I play trough monitors it works as it should.
This have worked before.
Is it anyone who knows what this could be?
Thanks!
Old 11-26-2023, 05:58 AM
Stephen Bond's Avatar
Stephen Bond Stephen Bond is offline
Default Re: Mute channel when recording in headphones
If you mute the channel but are still hearing it you are not only listening the mix from Pro Tools.
Your audio interface might be monitoring directly the input being recorded ('Direct Monitor' or similar on the interface).
Lastly, the interface could have additional software that is routing the input to your speakers?
Hope that helps.
Stephen
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2
https://www.waves.com/r/djgsi6
Old 11-26-2023, 06:41 AM
K Roche's Avatar
K Roche K Roche is offline
Lets back up (and maybe it's a second language thing )
But if you "mute the channel" you should not be hearing anything in HP's or speakers
The only exception to that is,, if you you are sending form the track to another track. (i.e. like say sending from the guitar track to a parallel reverb or delay aux track)
OR as Stephan mentioned if you have direct input monitoring on on your interface
System :
Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1
Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4
Enjoy the Journey
.... Kev...
Old 11-26-2023, 07:06 AM
Hi thanks for your answers.
Is the direct monitoring a setup in Protools.
Wouldn't it be the same sound that came out from the speakers? (without headphones)
I got an Focusrite scarlett 18/20 soundcard I got both speakers and headphones connected.
Old 11-26-2023, 07:39 AM
I solve the problem, it was a setup in Focusrite control.
You gave me the clue, thanks!
Quick Mute Headphones Feature? tekn0 Pro Tools | Carbon 8 12-27-2021 09:06 AM
Is there a way to MUTE a channel when punching in? Eric Seaberg Post - Surround - Video 10 04-27-2021 05:41 PM
No signal through right channel in headphones... stephesk8s 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-22-2011 07:15 AM
Channel Mute Issue lmiller VENUE Live Sound Systems 19 03-21-2011 06:07 PM
how can i mute tracks in headphones but not my monitor speakers? xstortionist 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 12-11-2009 09:22 PM
