Recorded Sound Issue
Hi all.
Can anyone tell me why the recorded sound I’m getting is not the same the monitored sound when doing the recording. The monitored sound is great. The recorded sound is second rate by comparison. To begin with, I’m trying to record some rhythm guitar parts. I’ve got a ’78 25/50 Les Paul, running it through a ’89 Marshall Custom into a 2x12 cab, which is in an isolation cabinet, and it’s miced up with a Sennheiser e609 10.5” from cone just inside the edge diaphragm. Interface: Focusrite Scarlett 18i20. Head phones: AKG K271 Mk II. DAW: Protools 11.1.3. Computer: ASUS G73J Laptop (i7 Processor, 8GB (2GB x4) DDR3 1066 SODIMM SDRAM). OS: Windows 7, 64 bit. To keep things simple I’m running the signal directly into Line 1 of the interface, through Scarlett Mix Control and then into Protools. The level is just dipping into the yellow. The monitored sound is big and fat and rich, just as you’d expect from Les Paul and a Marshall. There’s little leakage from the iso cab, certainly not enough to hear it through the phones. I’m using the iso cab so as to avoid the complexities of capturing a room sound and difficulty of monitoring the signal with all that speaker volume. So, what am I doing wrong? I’ve herd other peoples home studio recordings of rock guitar and they are of a high quality and an accurate rendering of guitar and amp. I’ve tried to purchase the right gear, I’ve checked all the vids, but I’m at a dead end. Any thoughts? Cheers, JC. |
Re: Recorded Sound Issue
Are you Record and Playback faders linked or unlinked?
Do you have any plug-ins active on the track your recording to? And welcome to the forum, please review the Help Us Help You link at the top of the page
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
Hi Craig.
Thanks for the prompt reply and welcome. I have three default plugins on the track: AIR Kill EQ; D3 Comp/Limiter; EQ3 7-Band EQ. All are bypassed when recording so their subtle effects are not herd. None improve the play back/recorded quality of the track enough to solve the problem. Record and Playback faders are linked in the preferences. Cheers, JC. |
There's been talk about this, and is not unique to ProTools, but seems to be common to all systems that record and play back linear PCM...
Do a google for the phrase 'Playback Disappointment' and you'll find some of that stuff... Certainly drives me crazy... |
Ta for the input regarding linear PCM. The only discussion I can find seems to be in relation to the play back of WAV files. And yes, I've noticed that, too. However, the recorded sound I'm talking about is from the native 'working file' format, not the bounced content to WAV.
Okay, I see that WAV is the working file format, not just the format I'm bouncing to. If this an inherent problem with WAV, is this a hopeless cause?
I've used .wav files for years (got off SD2s ASAP) and not had a problem as your describing with them
Hi Jay-Cee,
When monitoring you are hearing the audio directly through the Interface. When recording the audio also passes through the driver. So it is possible there is some issue here that we need to look deeper into. Can you please open a case with our Tech Team directly? Provide me the Case Number and I will see to it personally. We are happy to help. http://focusrite.com/answerbase/contact Best regards
Katherine Kaplan // Focusrite Technical Support http://www.focusrite.com/answerbase/en/ |
Hi.
Yes, when monitoring, I'm hearing the audio directly through the Interface. I'll start a case number. Cheers. |
Can you please keep us posted on the outcome of this, it may be very interesting.
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
Crossgrade from mpowered to pro tools 9 - Recorded songs playback issue | Mike1005 | Windows | 1 | 12-07-2012 01:09 PM |
Sound Changes When Recorded | ChronoCross | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 04-24-2011 09:08 PM |
11R LE no sound from song recorded in M-P | Credo Dei | Eleven Rack | 3 | 11-26-2010 04:29 AM |
No sound on recorded playback. | tfee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 02-16-2008 04:08 PM |
PT LE recorded song on Sound on Sound magazine art | yavuzj | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-19-2006 03:04 PM |
