Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools HDX & HD Native Systems (Win)
Old 06-16-2014, 09:24 AM
djmj djmj is offline
Default Protools HD8, spdif FW saffire le.
I built a new windows 8 x64 I7 Pro tools Hd computer. It's a PT HD4 with Texas instrument FW PCIe card. I wanted my computer sounds thru my monitor system. I bought a used Focusrite Saffire LE. Using spdif in/out between my digidesign hardware, connected my monitors on my monitor out "saffire".
It crashing my Pro tools after a second or two. "Overloading CPU. Check for compatible diskdrives etc and error message -6031.
Uninstall and disconnect my Saffire, everything works great. Tried with Legacy fw drivers. Same. Chrashing
I don't have friends who I can borrow a spdif soundcard and test compabillity with pro tools. Anyone have knowledge about this?
Should I go with USB instead or a newer FW card?
BTW it doesn't matter if I disconnect spdif cables, it's still crashing PT.
Hope someone understand me and can help.
Cheers
Johan
Old 06-16-2014, 10:03 AM
Craig F Craig F is offline
Default Re: Protools HD8, spdif FW saffire le.
This would make me believe it may be a Firewire conflict
http://us.focusrite.com/answerbase/i...rewire-adapter
Thank you,
Craig
Old 06-16-2014, 10:23 AM
I bought the best recommended FW card.
SIIG NN-E20012-S2 2-port FireWire PCIe Adapter - 2 x 6-pin IEEE 1394a FireWire400.
And I tried win 7 x 64, installed win 8 x64 instead, tried legacy fw drivers, nothing helps. Pro tools crashing/hangs.....
My saffire works perfect standalone, not together with pro tools, tried spdif/in out together with digidesign hardware, using line in/out instead of spdif, still crashing pro tools. Always same, pro tools hangs and error -6031.
Regards
Johan
Old 06-16-2014, 10:33 AM
I don't know, Foucusrite support may have an idea
feels like a class of drivers to me
a cheap sound card with SPDIF I/O would have been my first attemp
Thank you,
Craig
Old 06-16-2014, 11:17 AM
Seems like an expensive way to get audio out of the PC I use a Presonus Central station monitor/source switcher and feed the PC's own optical SPDIF out to the optical SPDIF input of the CS(push 1 button to hear all non-PT audio). Works like a charm, and I can still use the RCA SPDIF from PT if I want
Old 06-16-2014, 12:07 PM
Craig, I don't think focusrite gives support on outdated equipments. And albee, I do have spdif on my motherboard, but then I would need an spdif bracket, maybe it could work. But this Saffire was used and not to expensive, but as I cant use it as it is, maybe it was to expensive anyhow. But I didn't buy the FW card just for that reason. FW is great to have on a music workstation. I needed a monitor-controller as my avid C24 is broken. Gonna fix that console one day though.
Old 06-17-2014, 03:50 PM
Katherine_Focusrite's Avatar
Katherine_Focusrite Katherine_Focusrite is offline
Focusrite
Hi dmjm,
We do definitely support our discontinued products, such as the original Saffires.
On an issue like this we would want to gather a lot more information about your computer.
Please feel free to call us or email us directly.
Email: http://us.focusrite.com/answerbase/contact
Phone Focusrite Novation Inc: http://us.focusrite.com/stores/distr...20of%20America
Please contact us so we can assist you.
Best regards.
Katherine Kaplan // Focusrite Technical Support
http://www.focusrite.com/answerbase/en/
Old 06-18-2014, 08:46 AM
Originally Posted by Katherine_Focusrite View Post
Hi dmjm,
Best regards.
Hi Kat, Iam impressed you still support Saffire LE.
I have other focusrite FW devices to. I have a Liquidmix 32 I can test to rule out any FW/driver issues.
I can post my result along with full computer spec.
Thank you again Kat for reading the forums and trying to help.
Cheers
Johan
Old 06-18-2014, 07:49 PM
Barry Johns Barry Johns is offline
Hi dmjm,
Best regards.
Much respect for your company monitoring various boards and assuring current and future customers that you are there for them regardless. Much could be learned from your company's leadership! KUDOS!
HD Native Pcie, PTHD 11, PT12 Vanilla, Omni, Lynx Aurora 16, 192 I/O (16 in/8 out), 24 Fader D-Command, lots of preamps and compressors.
MacPro 5.1 (12) Core (2009 MacPro 8 Core Upgraded to a 12 Core MacPro), 56 Gig Ram, SSD System & 3 - 2TB Drives, OSX 10.9.5, Windows 10 Via Bootcamp
Old 06-20-2014, 12:27 PM
I have tested my liquidmix 32, and pro tools hd crashing after a few seconds with same error code, so it doesn't matter if it's a sound card or my liquidmix 32. I bought the recommended "expensive" FW card and I cant use firewire
This is an Avid "pro tools" issue. My Saffire LE worked perfect standalone.
I used def fw drivers and legacy FW drivers, same result.
Thanks Focusrite "Kat" but this seams to be an Avid issue.
Just as well by a USB soundcard and sell all my FW devices......
Cheers
Johan
Saffire Pro 40, ADAT & SPDIF? dr_daw Third Party Interfaces 5 10-14-2014 08:17 PM
PT 10 & Focusrite Saffire Pro 40 & tc elec. M-One XL SPDIF Problem mistamarc macOS 1 04-09-2014 06:31 AM
Using Focusrite Saffire Pro 24 with Protools 10.3.5 aussie45 macOS 6 06-25-2013 05:42 PM
Protools 10 with Saffire Pro 40 navneethbalachanderan Windows 3 12-29-2011 07:40 PM
Please Help Me...Focusrite Liquid Saffire 56 i/o with protools 7.4 LE Shocktone 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-28-2011 06:37 PM
