Old 10-27-2013, 07:45 PM
reichman's Avatar
reichman reichman is offline
Default Mixing stereo vocal stem into surround.
Working on a show where the transition from dialog to singing is intended to be very natural, and the songwriters are giving me stereo lead vocal stems. It's a little disconcerting going from dialog in the center channel to singing in the phantom center .
Should I require the songwriters to send me LCR mixes? Or am I being too picky and should I just live with it? I can't think of anything to do besides upmixing with Iosono.
Thanks in advance for any advice.
Nathaniel Reichman
Producer/Re-recording Mixer - New York
Nathaniel Reichman | IMDB | LinkedIn
Old 10-27-2013, 08:54 PM
The Cargo Cult's Avatar
The Cargo Cult The Cargo Cult is offline
The Cargo Cult
Default Re: Mixing stereo vocal stem into surround.
you can't just toe into center?
maybe drift out to sides over the first few lines?
Old 10-28-2013, 12:28 AM
Peter Cole's Avatar
Peter Cole Peter Cole is offline
Are there effects on the vocal track? If so you could use an UpMix plug in to give you hard center and the vocal effects will spread out making the transition easier.
Old 10-28-2013, 12:32 AM
Craig F Craig F is offline
run the 2.0 mix through a Pro Logic decoder, record the results
Thank you,
Craig
Old 10-28-2013, 09:07 AM
If I were the music mixer on this, I'd *definitely* want you to tell me that you need hard center; I'd want to mix the music with that in mind, and eq/effect the vocal in a hard center presentation.
The music mixer should appreciate good communication with the dub mixer in a situation like this. If they don't, or if they don't have the ability to generate LCR stems, well then, you gotta do what you gotta do...
best,
rich
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 10-28-2013, 09:15 AM
reichman's Avatar
Thanks guys, I really appreciate your experience with this.
...this is what I'm afraid of. I'm going to make the request, but I'm really not seeing a transition to LCR on the TV music side of things yet.
Nathaniel Reichman
Old 10-28-2013, 12:04 PM
alexbooy alexbooy is offline
You could make a MidSide routing from the 2.0.
That will give you a Centre and LR tracks, which you can mix to fit.
Alex
Old 10-28-2013, 02:50 PM
seanmccoy seanmccoy is offline
Alex
I was going to ask if MS would be the answer here. How would that affect the downmix? Would it be better to duplicate the track and dedicate one to C and one to LR?
Custom i9-12900K, 64GB RAM, W10 Pro, PT Ultimate 2024.03, HD Native, OMNI, Digi 192, UAD-2 Octo; Mac Pro 12-core 3.46, 64GB RAM, Mojave, Logic Pro 10.5.1, Apogee Rosetta 800, UAD-2 Quad, MOTU 2408 Mk II: MBP mid-2012, 16GB RAM, Mojave, MOTU 8-Pre-ES, Pro Tools 2021.7
Old 10-28-2013, 04:50 PM
Henchman Henchman is offline
Having mixed quiet a few projects with performance vocals, the best way is to either simply pan the stereo dead center, or use an unwrap plugin.
Also, I always make sure the music supervisor knows I want dry lead vocals.
No exceptions.
www.markhensley.tv
IMDB Credit List
Living the dream.
Old 10-28-2013, 07:54 PM
viaspiaggia viaspiaggia is offline
was about to post about a similar issue!
I do a lot of kids' stuff that has vocals and dialog blended, and I'm usually doing the music mixing so I can keep the vocals discreet center with my own verbs.
But on a current show I'm getting a few songs mixed by a music guy, and his vocal stem is stereo with effects baked in. I'm mixing some songs which will have my usual hard-center-vocals. To make matters worse he's using CLA Vocals which literally CAN'T make a dry and wet print. Was going to suggest him making a stereo with no delay or verb turned on, and one with, and trying a phase flop to pull them apart.
But would the Iosono or something else successfully pull the dry and wet apart? I had thought about M-S, too, but haven't played with that inside PT - got a good suggestion for a plug to decode?
thanks!
Mac mini 2018 i7
ProTools Ultimate Native
Focusrite Scarlett 18i20
Atmos 7.1.2
hugmonstersound.com / unheardof.world
HTML code is On
How to bounce surround stem tracks peter5992 Post - Surround - Video 14 04-01-2013 12:38 PM
Mixing to Stem Peaks instead of Master Bus..frustrating DarthFader777 Post - Surround - Video 5 09-07-2011 03:55 AM
Surround Mixing / Stereo monitoring with Soundcode Stereo Meads Post - Surround - Video 6 01-04-2011 04:52 AM
Stem Mixing on LE? rickf 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-08-2007 01:56 PM
STEM Mixing Help. e.g. PT to Dangerous Bus Khaarmeyer Tips & Tricks 7 12-17-2003 08:23 PM
