Novation Automap 4.2 plugin control problem
Hello,
Just bought a Novation Impulse 61 and installed Automap 4.2 which was incredible for about 10 minutes. I installed and linked Automap to all my plugins and had no problem controlling parameters using the knobs on the Impulse for a bit, then all of a sudden, the knobs stopped changing plugin data. The knobs still show the correct plugin parameter both on the blue screen on the keyboard and within the plugin window in PTs, but when I move the knob, the value is frozen and inputs no changes. Anyone had this problem before? Thanks! Matt |
Re: Novation Automap 4.2 plugin control problem
Did you turn on preview mode on the keyboard? Shift and Controls/Preview button. This is so you can tweak the knobs to see what it's controlling, without changing values. Just a thought
I had pressed a few buttons on the Impulse including the Shift/Learn but Preview doesn't seem to be lit up and I've successfully shut off Preview mode without fixing the problem. Thank you for trying though!
Did you fix this? I had tons of issues getting my impulse to work right. I found I had to run automap as administrator and I had to reset up protools after my preferences crashed.
I did fix it, but I really have no idea how. I'm not one to let things go unexplained but I restarted Pro Tools and the Impulse a few times and eventually the problem just went away. I do now have a brand new problem with the Impulse which is that the C3 midi note sends random on messages constantly. I've discovered that it's somehow related to the bottom left drum pad and that when I press that pad the C3 note ceases temporarily only to start up again soon after. Fun stuff. Novation tech support suggested I use Snoize to suss out the midi messages but I haven't gotten around to trying it yet.
www.snoize.com Midi Monitor |
Novation Automap and ReWire | rikttt | MIDI | 1 | 03-22-2014 03:21 AM |
Novation Automap and Pro Tools 10 | Dopamine | Virtual Instruments | 0 | 04-19-2013 01:40 PM |
Novation Automap 4 and PT 10 | Moviesound | macOS | 8 | 09-16-2012 10:07 AM |
Novation Automap...again | AtomicBeagle | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-11-2009 07:25 PM |
Automap for Novation ReMOTE SL now available! | Sonny in London | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-06-2006 03:24 AM |
