Pro Tools 7.4.2 crashes on Leopard 10.5.3 / MACBOOK 2.2Ghz
I have installed Pro Tools LE 7.4.2 on my Macbook Dual 2.2 GHZ running 10.5.3, all of which are meant to be fully qualified but i cannot re-open saved pro tools sessions.
I am able to create a new session and save it on finishing the session but then am unable to re-open the files. Pro tools will boot up but when it gets to "building miscellaneous views" (as it opens/builds the session) it crashes. This happened on the pre-release version of 7.4 i was using and hoped the 7.4.2 release would fix the problem but it hasnt. I have uninstalled and re-installed pro tools and still the same problem persists. Does anyone have any advice/solutions for me? thanks |
Re: Pro Tools 7.4.2 crashes on Leopard 10.5.3 / MACBOOK 2.2G
1. Did you do a clean uninstall of the pr version? If not, it could be the issue that affected that is still around. Don't forget to trash prefs/DDB's and repair permissions to.
2. Are your third party plug-ins bang up to date? e.g Rewire stuff like Melodyne Uno need updating. You could move the plugs to the unused folder and put them back one at a time to test this. http://www.myspace.com/philogg |
thanks for your thoughts....
i definitely did a clean uninstall maybe i should check the plug-ins i am running pro tools le's bundled plug-ins plus the latest versions of t-racks and sampletank will remove them in the morning and see if that helps, then post up on here again. thanks mate |
no change as a result of removing the plug-ins (which are actually qualified as compatible in Pro tools 7.4.2 anyway)
admin......do you have any advice. This is very frustrating as i bought my mbox mini in january when i bought my macbook as my mobile studio set-up and i AM STILL UNABLE TO USE IT!!! i have always been a pro tools fan since getting digi 001 but am now being forced to use logic as pro tools have taken so long with leopard compatability (which i still dont seem to have on my macbook ) |
Macbook Pro 2.2ghz and Pro Tools LE 8 | scatcat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-27-2010 12:09 PM |
PT-LE 8.0.3 MacBook Pro & Snow Leopard Crashes | Cryos | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-14-2010 02:23 PM |
Ageing G5 2Ghz Powermac - Leopard 10.5.5 | pmcmurt | Pro Tools TDM Systems (Mac) | 13 | 01-27-2009 03:59 PM |
Is a MacBook Pro 2.2Ghz okay for PT 8? | Monaco | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-04-2009 04:40 PM |
macbook pro 2.2Ghz | merman1983 | General Discussion | 4 | 11-18-2008 02:06 AM |
