cs 10 control surface for Protools M-powered 7.4
Please i'd like to have control surface for Protools M-Powered 7.4 because control surface for Protools M-Powered 7.3 don't work.
Thank you |
Re: cs 10 control surface for Protools M-powered 7.4
Same here please. I got the cs-10 bundle in the controllers folder but it doesn't appear in the peripherals list.
Forgot to mention I'm on 7.4 le so I might be in the wrongbit of the forum, but still... |
Found an update for the cs-10 controller for 7.4 all seems fine now. thanks
Here's a link to the Legacy Controllers Page that has a link to the 7.4 controllers download, in case anyone else is interested and doesn't feel like doing their own search for it.
I just upgraded to 7.4 on a PowerMac G5 and PT still can't see the CS-10 even when I reinstall PT 7.4 and place the CS-10 from Digi's web site in the correct folder. Am I supposed to do anything other than put the bundle in Apps/Digidesign/ProTools/Controllers?
Thanck You Digidesign for cs10.It work fine.
My problem is solved.
I have two HDs in my rig. The apps, including PT 7.4, (and the OS) are on one of them ("Main HD"), and the sessions and audio files are on the other ("Second HD"). It turns out that as I was messing around with trying to get this to work, I had left a couple of old (v7.0) versions of the CS-10 personality on the "Second HD". Apparently, when I launched PT 7.4 from "Main HD" (that is, launched the application and not double clicked on a sesssion), it picked up the correct CS-10 personality (the one which was in Main HD/Apps/Digidesign/ProTools/ Controllers), as that folder is on "Main HD" with the PT application. When I launched PT by double-clicking on a session, however, it seems that the launching process "picked up" the old CS-10 personality from the drive the session was on ("Second HD") and tried to use that one. I'm not sure why this would have happened, but once I removed the old CS-10 personalities from the "Second HD", everything works fine. PT can see the "correctly" placed (V7.4 personality in Main HD?Apps/ Digidesign/ProTools/Controllers) whether I launch from the application itself (on "Main HD") or from a session (on "Second HD"). |
Control Surface For Protools 10 Mackie Pro Control or Avid Artist Control | lberrios1962 | Pro Tools 10 | 18 | 05-26-2012 12:51 AM |
Protools LE 8/Mac OS: ipad control surface | Matt Darcy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-13-2012 03:33 AM |
Problem using Novation control surface with PT M-Powered | juanfranela | Pro Tools M-Powered (Win) | 3 | 12-29-2009 12:13 PM |
Using a Motif XS as a control surface for Protools | Reb | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 09-25-2009 07:56 PM |
002 or 003 as a control surface for ProTools HD | jjtsf | Pro Tools TDM Systems (Mac) | 1 | 12-01-2007 03:04 AM |
