Old 07-15-2014, 05:40 PM
Gabriel Sullivan Gabriel Sullivan is offline
Default Digi002 and Focusrite 18i20 not getting ADAT signal
I am running Pro Tools 11 with a Digi 002 and a Focusrite 18i20 connected to the 002 by optical . .. I see good levels coming into all 8 of the focusrite channels but I can not get any levels on the 8 ADAT inputs in Pro Tools. I tried adjusting the 002 Hardware settings but still nothing . .. Help?
Old 07-16-2014, 01:03 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Digi002 and Focusrite 18i20 not getting ADAT signal
In the hardware settings have you set the digital to optical adat? And on the inputs selection box you set inputs say 9-16 to receive optical adat?
The session is 44.1 or 48k?
The Focusrite is set to receive external clock.
Digital connections to and from the Focusrite
Chris
Producer, Engineer,
www.ukmastering.com
Old 07-16-2014, 10:38 AM
Katherine_Focusrite's Avatar
Katherine_Focusrite Katherine_Focusrite is offline
Focusrite
Hi Gabriel Sullivan,
Have you set up the 18i20 for Standalone mode properly?
You have to tell it to route it's Analog Inputs to the ADAT Outputs.
Please see the guide here:
http://us.focusrite.com/answerbase/h...tandalone-mode
Best regards.
Kat
Katherine Kaplan // Focusrite Technical Support
http://www.focusrite.com/answerbase/en/
Focusrite 18i20 Disconnecting with Pro Tools 11 SuperDave71 Third Party Interfaces 4 06-20-2014 06:43 AM
Focusrite 18i20 won't power on. Woodybear Third Party Interfaces 3 04-03-2014 04:19 PM
Focusrite 18i20 won't detect when switching on Kollen.col Third Party Interfaces 11 03-26-2014 02:04 PM
Focusrite 18i20 MEWCO Third Party Interfaces 17 03-03-2014 09:37 PM
Pro Tools 10 disconnects my Focusrite 18I20 Peter Warren Pro Tools 10 0 12-13-2013 12:31 AM
