#131
Re: Audio tracks stop playing back/outputs disable
Just came across this problem as well. 16 tracks on a large session just stopped passing audio. Meters were working, just no sound. Moving any fader of the grouped tracks corrected the problem. This is an insidious bug as you don't ever know if all your tracks are playing back at any given moment. Every thing can be working fine.... you finish your mix, go to print for a client and then things are missing that you may or may not catch!!!! NOT GOOD. For a studio to pay $1500.00 for this privilege (v.8>v.10), is a little insane. At this time you can't really trust PT10 as in previous versions. Hopefully this gets fixed pronto.
PTHD6 / C|24 Controller / Euphonix MC Mix Controller / PT v.10.2 Intel MacPro 2.8ghz Quad Xeon / 18gigs ram/ PE6R4 Expansion Chassis w/Core,4 accel,1 process card, 46" & 24" monitors Syn-g www.bulletsage.com |
#132
Thanks for responding DTS My problem, DigiTechSupt, is that none of the user posts here describing their interaction with tech support had anything from tech support even close to the simple things needed to make this bug appear. There were convoluted things to do from them that were supposed to make this happen, or there were very minimal attempts for a fix (like having the DSP Cache turned off). It doesn't take much at all to make this happen, just normal things, as described very clearly in my original posts. In addition it seemed like most or all the mentions of tech support here were non-US Tech support. SO IT SEEMED like to a lot of us that Stateside Avid was not paying attention. I'm glad that's not the case.
Pro Tools 10/11 HD, Mac OS 10.8.2, Mac Pro 2 x 2.4 GHz 6-Core Intel Xeon (June 2012) 64 Gig RAM, Avid HDX Card, OMNI HD I/O, 192 HD 16x16, Artist MC Control, Firewire audio drives, Sony Bravia 42" HDMI monitor, Acer 24" monitor |
#133
Both examples you sited were non-US tech support, hence my apprehension that something was wrong Stateside. The first example has the WAY over complicated method to make this problem appear. It is much simpler, as again, my original posts make clear. You don't have to go to nearly so much trouble to make this bug appear. Thanks
#134
I agree. All that it takes to make this happen is to create new tracks. It may not happen the very first time that you create them but if you continue to create new tracks, sooner than later, the problem will present itself.
There is a separate thread about automation not playing back that is also brought on by creating new tracks. Even though this problem is being discussed in a separate thread I believe that the underlying cause of both problems might just be the same thing. We need to keep this discussion going until this quite hideous bug is eradicated. |
#135
bump
#136
Is this still a problem?
I've got the 10 update but am hesitant to upgrade from my working v9 rig Really want to jump on v10 Hopefully can do by the new year. Is the problem still consistently bad for folks? |
#137
Hi all,
just had another automation fail on my reverb. Automated it to -infinity. The fader moved, but the tail was still fully audible. Restart worked. Avid, please fix this. This is definitely the greatest bug I've come across, that makes Pro Tools an amateur software. Hope this is the biggest priority and on my Christmas list. Timothy |
#138
Yes - it's still a problem.
#139
+1.
#140
Finally..... same here!
First no automation on my fx and today no sound on lots of tracks! Now I´ll reboot and restart PT before I print the final mix! Wow! PRO Tools!! Thought HD 10 is stable as a rock... NOT!!!! |
some of my vocal audio tracks not playing back...help | superdood | Digidesign Hardware & Software | 13 | 11-19-2021 08:31 AM |
Audio tracks stop playing back/outputs disabled in PT 9.0.6 | mingojr | macOS | 0 | 08-12-2013 05:25 PM |
Recorded audio is not playing back in sync with other tracks | ATLracing | Getting Started | 4 | 07-08-2013 05:52 PM |
Those getting "audio tracks stop playback/outputs disable" Questions? | crizdee | macOS | 15 | 09-25-2012 08:10 AM |
Tracks Stop Playing Back 7.2.1cs1 | tomhartman | Pro Tools TDM Systems (Mac) | 0 | 11-21-2006 01:36 PM |
