Pro Toos 12 Activation??
I have been using PT 12 for a while but when I loaded PT12 this morning, it is asking me "select license to active". How can I fix this? I have already checked my iLok. It is working and I downloaded a new copy of the iLok License Manager ans still no luck. Please help.
Re: Pro Toos 12 Activation??
Disable your USB power management so it doesn't shut off the USB ports?
My usb ports work. I already tested them
Ok, but did you disable power management? That's two seperate things....
My iLok works fine. It lights up and windows recognizes it
BUT if you didn't disable USB power management, it'll eventually shut off the USB port because it thinks it isn't being used, then your I-lok disappears and creates exactly what you're describing. Checking costs nothing.
I got it working. It had nothing to do with the USB port but than you for your help :)
Pro toos 10 lost license after format | Aima | Pro Tools 10 | 12 | 03-30-2015 03:34 AM |
Pro Toos 11 Cross grade from LE8 | juca2929 | macOS | 7 | 09-25-2014 03:31 AM |
regular pro toos 8 trying an m audio firewire 410 | smoochdaddy | Pro Tools M-Powered (Win) | 2 | 11-08-2009 04:30 AM |
Pro Toos 8 Reference Guide still not available in the UK! | Intini | Pro Tools TDM Systems (Mac) | 6 | 03-12-2009 08:09 PM |
sound replacer crashes pro toos | firedog57 | Pro Tools TDM Systems (Mac) | 2 | 10-05-2004 08:38 AM |
