Assertion in \"Cmn_Interval cpp\' line 103
Error: Assertion in "Cmn_Interval cpp" ,line 103
Hi , when i trying to compact the session if 8 mono tracks and 4 stereo tracks under 6.1 10.2.8 It says Assertion in "Cmn_Interval cpp" line 103 and when I hit ok, the protools progress bar telling "Analyzing region list" appears and PT freezes. Any ideas? I Wait your help , tanks !!!!! Andre Servolo , Rio de Janeiro , Brazil [email protected] |
Re: Assertion in \"Cmn_Interval cpp\' line 103
Also having this problem with a client's system (800MHz Quicksilver G4, lots o' ram, OS10.3, Mix plus, PT 6.2.2. all pt sessions run off of scsi drives w/ ATTO card).
When using the trim tool on certain regions/tracks in a session imported from an OMF file, this is the error: Could not complete your request because Assertion in "Cmm_Interval.cpp", Line 103 tried the following, nothing worked: 1. Imported existing tracks into new session 2. duplicated file of problem region (consolidated region) 3. did a save session copy... copying audio files and plugin settings but not fades also, I could find nothing about this in the answerbase. They imported several OMF sessions and this is the only problem one. any insights would be greatly appreciated! |
Sometimes bad automation at the end of the session can cause this. The workaround is to delete the bad automation at the end of the session by option-clicking. Time selection cannot select the break point to be deleted. Try this and see if it helps. You can try using import session data a couple of tracks at a time to see if it is isolated to a particular track. I hope this gives you an area to look in. Thanks, Digidesign Tech Support |
Assertion line 74 | mikeeovitch | macOS | 0 | 10-08-2011 05:53 PM |
Assertion in 'Sys_VolumeMacOS.cpp' line 692 | rexdigital | Pro Tools TDM Systems (Mac) | 2 | 12-02-2008 10:45 AM |
what is "assertion in 'BDM_workspace.cpp' line" | scotty_perey | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-28-2005 06:37 PM |
Warning I've never seen Cmn_interval cpp,line 103 | Kurtstudio | Pro Tools TDM Systems (Mac) | 3 | 03-10-2004 07:39 PM |
Error: Assertion in "Cmn_Interval cpp" ,line 103 | Impala | Pro Tools TDM Systems (Mac) | 0 | 01-02-2004 12:14 PM |
