Reverb and Compression on Drums
I was just wondering how all of you put reverb and compression on mulitpe drumset tracks.
Eric PT M-Powered 7.3 |
Re: Reverb and Compression on Drums
The typical method for using the same effect on multiple tracks is with sends on the tracks bussed to a stereo aux track with the effect inserted on the aux. Reverb is typically set 100% wet in a situation like this and blended with both/either the send level and/or the aux level.
Many of these techniques are covered in the archives of the digizine, especially the LE Bootcamp Archive. You might want to take a look at some of those arcticles. A good book on protools might help, too.
are there any reasons for using either just the send level or the send level & aux level for balancing the reverb. what are the pros and cons of each or is it just a personal preference thing?
thanks
PT LE 7 & MBox Windows XP SP2 P4 3.0GHz CPU, Intel 865/PE/P Chipset 1GB RAM 2 X Seagate Barracuda 80GB HDD Novation Remote SL MIDI Controller |
Should the send be set to pre or post?
An understanding of mixers in general might help: This Article might be useful to you, as well as the site that it is linked from.
Pre-fader sends are for things like headphone mixes, where your fader moves don't affect the headphone mix. Post fader sends are typically used for effects so that when you move the fader down, the reverb goes down with it, for example.
Compression is typically used as an insert, and is not driven by a send. You "insert" a compressor on a channel in Pro Tools the same way you would on a hardware mixer. Reverb and effects are driven by a "send", or "aux send" on each individual track, and are typically not used as inserts, just as with a console. You may want to "send" more snare to the reverb than kick, for example. It is not necessarily a book on Pro Tools that you need, it is material on general recording techniques and practices that will help you. Recording on computers evolved from recording on tape through hardware consoles and devices, and the same basic fundamentals apply. |
Panning reverb and compression? | pakobo7 | Pro Tools M-Powered (Win) | 4 | 07-02-2007 09:38 AM |
Getting Reverb Delay and Compression | jsavi | VENUE Live Sound Systems | 1 | 05-09-2007 05:39 PM |
basic compression and reverb together | LL Lush | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-26-2004 11:09 AM |
Quality plugins? Compression, EQ, Reverb | sundial | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 05-07-2004 08:03 AM |
Reverb, Compression, etc. while Recording? | jlnelson19 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-18-2002 07:44 PM |
