Re: Eddie when are we going to get an update for the dock?
I didn't say nobody, I just said that I've never worked with someone who does. In terms of features off the top of my head...
Focus - selecting something (like an insert) in protools brings that up on the dock and app Clip FX control Having the option for the monitor knob to be assigned to pan instead of having to go to the pan page making the eq know control the ‘q’ by pressing the knob temporary mix groups for selected tracks eucon shortcut One page where i can access the controls for my channel. Pan, level, eq Clearer active track name - because it doesn’t always switch correctly Stable dock connection being able to assign group mute and solo soft keys having the dock change the numerical displays on channel strip Search in eucon assign page Assigning audio suite to softkeys |
That's great, thanks, see below, anything not commented on we know about and plan to do.
making the eq knob control the ‘q’ by pressing the knob ---- knob top is clear so changing it would effect everything -
Don't understand what you mean - we just need to be able to switch to eq 'q' without having to press the fiddly iPad screen. Pressing down on the frequency knob would be the best solution temporary mix groups for selected tracks eucon shortcut ---- not sure what is meant by this ? We constantly have to adjust multiple clips at at time with the fader. Setting up a group to do this overtime is far too slow. In other daw you can simply select multiple channels and they all will be affected. Having a softkey that turn on/off a temp mix group for what ever channels are selected would be a lifesaver for projects, like in film where we have 100's of tracks running One page where i can access the controls for my channel. Pan, level, eq ---- isnt this the channel page? Or are you talking about custom knob set? No, there are separate pages for all these. Makes no sense. It should all be on the same page having the dock change the numerical displays on channel strip ---- not sure what this is ? For example, when you adjust the channel strip eq, the pro tools plugin does not change its values on the pro tools screen |
I'm not sure how you could fit all the controls of a channel on to one page ?
Not displaying changes in the channel strip plugin when turning a knob on the surface sounds liek a connection issue...an chanec of a video showing this ? |
I think you could easily have an extra pane with all the controls. A much better solution would be to when in that pane, to have the monitor control to control whatever control you last touch. Left hand to select the control, right hand to adjust it with the knob. That would be the fastest solution
In regards to the display changes...are you saying that if you adjust say the gain of a channel strip band, that the pro tools plugin changes to that pane and shows the numerical changes as you do them? I don’t think they do. I could be wrong |
Moviesound. I hear you on this
Basically the concept is to have one page that is basically a one-stop shop with basic params.(clip gain, pan, high pass filter, attack, release, threshold, and maybe frequency and gain of the basic 4 or 5 bands of the first eq plugin). If more detailed params are needed then flipping over to the eq or dynamics tile would always be there too. http://protools.ideascale.com/a/dtd/...ms/260992-3779 |
Hello, Eddie -
Hope all is well! I work in post audio and would LOVE to have flip fader ability for The Dock. I'm sure this has been mentioned elsewhere, I just can't seem to come across it right now. Thank you, G.
Garrard Whatley Seismic Post Audio Post Audio for Film and Television System/Hardware Info IMDb credits |
Yes Flip for the Dock is on the list.
Thank you very much for confirming-- I'm very happy to hear it.
G. Sent from my LG-H872 using Tapatalk
The plugin numerical values do change -- you just want the main screen to focus on that change (follow mode) where it pulls that back into view. I agree it is dumb that pressing the knob on the frequency does a "reset" (one of the least needed things and should be done with a modifier) vs bringing up "Q" on EQs. Having to tap "sel" on the touchscreen to get there is dumb -- and the dual value encoder has been a staple to eq design forever (whether a push or concentric) |
Message for Eddie Jones | robertg | Artist Series | 11 | 01-25-2018 05:19 PM |
Eddie, your PM box is full apparently! | mattrixx | Avid S1, S3, Dock and Control App | 1 | 09-28-2017 07:05 PM |
@Eddie - Windows Errorlog - Can you help me? | Feinbeat | Artist Series | 5 | 09-22-2017 10:59 AM |
Suggestion: Users of S3&Dock together: dock fader becomes 5th VCA master fader | bassmagnetic | Avid S1, S3, Dock and Control App | 0 | 10-01-2016 08:20 AM |
Free Eddie Kramer Signature Series Guitar plug-in + Win a Free Mix from Eddie Kramer | unkJE | AAX Plug-ins | 2 | 01-09-2015 03:50 PM |
