Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
Old 12-21-2023, 04:11 AM
robertszydlo robertszydlo is offline
Default DAD TB Driver not seeing the TB3 card
My TB3 has arrived but I unfortunately can not make it work.
I cleaned the slot in the MTRX Studio and installed the hardware.
I updated Firmware to 1.1.3.1, Dadman to 5.7.0.1
I installed DADTBDriver CoreAudio 1.1.26
DADman can see the TB card (it appears in con routing matrix) and it can see the connection to computer - when the TB cable (Belkin 40 Gbps 2.6 ft TB3) is disconnected the red triangles appear in TB con , when it is connected the triangles disappear. The thunderbolt controller in MacOS System Report ( 12.7.2) can see the connected device to port - link status 0x2 speed up to 20Gb/s x 2
TB Driver installs correctly and says System Extension: Activated , it opens but there is nothing to select ( no device, no sample rate, no Channels )
Rebooted, reistalled, tried the second port, nothing hepls.
Please help , what can be the issue?
Thank you very much in advance!
Old 12-21-2023, 04:48 AM
tope d's Avatar
tope d tope d is online now
Default Re: DAD TB Driver not seeing the TB3 card
Hi Robert!
I’ve started a support case for you under case
04730801 so the team can assist you further.
Thanks!
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
Old 12-21-2023, 04:58 AM
Originally Posted by tope d View Post
Hi Robert!
Thanks!
Thank you!
Old 12-21-2023, 05:19 AM
Hi Robert!
Thanks!
How can I access the case?
When I log into my account I can only create a new case , how do I see the case that is already open? , thank you
Old 12-21-2023, 05:54 AM
tope d's Avatar
You’ll receive an Email for this.
Thanks!
-Tope
www.topedomingo.com
Old 12-21-2023, 09:03 AM
Does anything show up under macOS Audio MIDI setup?
Your profile says Mavericks, what release are you actually using here? DAD claims Big Sur is the earliest macOS supported, and given this is a modern AudioDriverKit based driver might well have issues on older macOS versions. Edit.. (12.7.2) means Monterey so that looks good.
Old 12-22-2023, 06:21 AM
Hi, thank you. I realized my profile info was not edited for years, sorry for this :)
Old 12-27-2023, 09:26 AM
off the wall's Avatar
off the wall off the wall is offline
Did you ever get an answer to this issue? I have exactly the same symptoms on my obviously unsupported system. DADman sees the MTRX Thunderbolt i/o, Mac System Profiler sees the device on the TB bus, other things work fine on TB (drives, UAD card in a TB chassis). It's the DADDriverSetup what won't see the MTRX Studio and create a Mac Core Audio device.
offthewallproductions
Mac Pro 5,1 3.46 Ghz 12 core, Open Core 0.9.8, Radeon RX580 GPU, GC-TITAN RIDGE TB3 PCIe card, M.2 NVMe SSD boot drive on PCIe card, 48GB RAM, macOS 12.7.4
Pro Tools Ultimate 2024.3.1/HD Driver 2023.3 HDX, UA Octo PCIe card in external TB3 chassis, MTRX Studio I/O, C|24 control surface.
Genelec 1031AP/7070A 5.1 monitoring.
Old 12-27-2023, 12:37 PM
Originally Posted by off the wall View Post
Did you ever get an answer to this issue? I have exactly the same symptoms on my obviously unsupported system. DADman sees the MTRX Thunderbolt i/o, Mac System Profiler sees the device on the TB bus, other things work fine on TB (drives, UAD card in a TB chassis). It's the DADDriverSetup that won't see the MTRX Studio and create a Mac Core Audio device.
QT ver & Fuse-X card/driver Phil Jeffers Post - Surround - Video 10 03-12-2008 05:43 AM
Working driver for Ignitor card and PT7.1 soundboy35 Post - Surround - Video 3 10-12-2006 09:01 AM
Promax display card driver for os9?? speedyk5 Pro Tools TDM Systems (Mac) 1 12-31-2004 04:07 PM
d24 card and coreaudio driver CStern Pro Tools TDM Systems (Mac) 3 11-25-2003 08:08 AM
Driver for Audiomedia III card. GunnarO 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-04-2002 10:50 AM
