First AIR Instruments Bundle not showing in PT 12
I installed Pro Tools First with XPand 2 and used it for about a couple weeks and have spent my time learning about the software and how mix engineering works. There is still a lot to learn and I like this software. I purchased the "First AIR Instruments Bundle" for 19.99 in the Marketplace, downloaded and installed it, then restarted Pro Tools. I also verified the bundle is in my Avid account. I cannot find the bundled instruments listed where you add the plugin to a track.
Can anyone help? Last edited by RaySolomon; 07-28-2016 at 02:24 PM. |
Re: First AIR Instruments Bundle not showing in PT 12
Hi and Welcome to the Community
I have sent this off to Avid Admins so someone will help answer this as soon as possible. In the meantime please read this and post the specs of your computer and OS etc so we can help better: http://duc.avid.com/showthread.php?t=300050
If you expose the Instrument class what is in there?
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
All the stock plugins that have been there since install.
Windows 7 Pro 64 Bit | Custom built Intel quad core 3.2 GHz with 8 GB Ram | Pro Tools 12 First w/XPand 2 |
I'm having a similar issue with my PT 12.5 HD. None of my original instrument pack is available? I've checked the aax folder and they are not showing there. I can't find an install for axx only .dpm?
See http://avid.force.com/pkb/articles/t...-Tools-install
Re: First AIR Instruments Bundle not showing in PT 12 [Solved]
UPDATE 08/09/2016 I think I fixed the issue by installing a trial version of Melodyne because I was curious about their audio to midi editing capability. During the installation process it had me install their 64-bit VST plugin, then I used the software to convert audio to midi which was easy to use. I was then curious about importing the midi file into Pro Tools First 12 and making some edits there. So I created a new Instrumental Track and clicked to INSERT a new multichannel-plugin and I now see the purchased Instrument Bundle that previously wasn't showing. Ya! Problem Solved. Installing another VST plugin somehow got Pro Tools to take notice of all the newly installed plugins.
Instruments not showing in Inserts | robert1 | macOS | 0 | 02-15-2013 08:11 PM |
Sibelius 6.1 is not showing in instruments | pipeorgan | Pro Tools M-Powered (Win) | 2 | 09-04-2012 02:40 PM |
Sibelius 6 not showing in instruments | Choral14 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 16 | 07-16-2010 05:33 PM |
Gold Bundle not showing up | Preston Klik | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 04-02-2000 01:00 PM |
