Rewire Slave Buffer Size
How do you lower the buffer size for a DAW that's Rewired into PT8?
My playback buffer in PT8 is set at 1024 but my buffer size in rewired FL Studio is at 8000 samples. |
Re: Rewire Slave Buffer Size
In my opinion, and personal hands-on experience with FL Studio, unless you are dead-set on using FL Studio... don't.
Yup! Reason will follow both the buffer setting as well as the tempo you have set in Pro Tools!
www.HellfireBeats.com UAD 2 Apollo Quad w/Thunderbolt 3, UAD 2 Satellite Octo TB3, UAD 2 Octo PCIe, Avid S1, Neve R6 500 Chasis, Neve Portico 511, Neve Portico 551, Dangerous DBox+, Focal Trio6 Be, Neumann TLM49, Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61 Pro Tools 2021.12 Mac Pro 7,1 2019, 8 Core, 48GB RAM - MacOS 11.6.2 16" MacBook Pro 2021, M1 Pro, 16GB RAM - MacOS 12.1 27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - MacOS 10.15 |
The only major problem I have with FL is the ReWire issue. At first ReWire wasn't working at all. It was freezing up all the time. Now it works but there's just this latency problem. Other than that FL Studio does its job. |
It's working for every other Rewire client I've tried. Quote:
I've owned it for a long time (actually purchased for me by a client!), but I have ALWAYS had problems with it one way or another, going all the way back to version 4.5 up to and including the new 9.5 beta. There are actually posts about this already on the image-line forums, but they seem to blame the host (in this case, Pro Tools) for communicating the buffer size incorrectly. They may be right; it could be a bug in Pro Tools, but then wouldn't every rewire client have the same problem?
I don't know which DAW is at fault, that's why I posted the problem in Image-line forums also. If ReWire's working well for you with other DAW's, then I guess the fault lies with FL. Now I just need to know how to fix it. |
Unfortunately, the only fix will be an update to the program code, no matter which program is at fault.
I'm afraid so.... |
Regarding using ReWire to connect another DAW as a slave... | stpete111 | Virtual Instruments | 7 | 05-10-2011 02:00 PM |
Increase Buffer size/Decrease Buffer size? | kerick | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-28-2006 12:00 AM |
Pt rewire as a tempo slave? | mashed meat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 05-01-2005 11:53 AM |
Increase buffer size...decrease buffer size.... | Bodhisan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-08-2005 07:24 PM |
New VST rewire slave available! | who | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 10-20-2003 09:31 PM |
