question about interfaces: PT Mix
Can anyone tell me if an 882/20 will work alongside an AD 8000?
I have the apogee connected to my PT mix core card and the 882/20 connected to a farm card. I have BNC out from the apogee into the 882/20. The slave light comes on. I have assigned the 882/20 in the audio core manager and made sure the I/O setting were good. No signal returning from the 882/20 back into PT. I tried this with an 888/24 as well with the same results, but I suspect the 888/24 may be toast as I am seeing random signal spikes on the meters on the front when I connect it to the AD 8000. Any help would be appreciated, Thanks in advance. |
Re: question about interfaces: PT Mix
Does the 882 work by itself? Sounds like a clocking issue, bad clock cable maybe?
Thanks milesofwire, I'll check the cable. I made the cable myself with a 75 ohm cable and some BNC connectors with the proper tool to secure the ends, and checked it with a volt meter.
It could be that the cable is not to spec in some way. It's original purpose is to run a security camera. I figured that it was something else, and that if the cable wasn't working I would still get signal, but with clocking issues. You are saying that if the BNC cable isn't correct from the AD 8000, I will get no signal from the unit to PT? (I checked the 882/20 on it's own, and it does work) I will pick up another cable from an electronics store and check it out. Thanks again milesofwire. |
Also are you sure the cable is good coming from the farm card? Had many mix cables go bad after a while. Try swapping those if the other does not work out.
Mike |
What do you mean "audio core manager"? In pro tools you just go to the I/O setup window. Are you talking about the digi core audio manager? As in PT 6.4.1? Because that only supports 8 I/O.
One other thing. I believe if you use 2 interfaces you should hook them up with a Y cable to a single card. |
audiogeek: Thanks, I did try swapping the cables and they both work.
BG music: You're correct...I mean the digi core audio manager. However, you must be mistaken about 6.4.1 not supporting more than 8 I/O. PT manuals for that version discuss connecting extra interfaces and setting up I/O for more inputs. Someone please confirm this! Thanks all. |
I run Mac OSX 10.3.9 panther with PT 6.4.1 I wasn't even aware of another driver. I appreciate your help. |
I'm confused, BGmusic, the digicore setup window allows for setup of multiple interfaces, The I/O set up does as well, the manual discusses set up of multiple intefaces, people use multiple interfaces with PT mix systems...so how can this be? How can the only driver available for PT mix systems accommodate only 8 I/O, when clearly many users incorporate 16, 24 + I/O, as well as the manual instructing setup for multiple interfaces?
What am I missing here? Thanks. |
HD Native with 2 blue interfaces hookup question | Justin1524 | Pro Tools HDX & HD Native Systems (Mac) | 5 | 09-03-2013 09:49 AM |
Question about Pt9 interfaces | Raggi | Pro Tools 9 | 7 | 05-01-2011 07:22 PM |
Urgent question about old Digi interfaces | Alécio Costa | Pro Tools TDM Systems (Mac) | 5 | 06-08-2005 05:25 AM |
OT: MIDI Interfaces- 3 in and 8 out question | edgarbc1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-04-2004 01:53 PM |
Compatibility question about MOTU interfaces | JeffT | Pro Tools TDM Systems (Mac) | 0 | 10-19-2003 04:11 PM |
