[D-COMMAND] HELP#2 - Stereo Monitor and Headphone
Hi everybody,
I desperate need some help here, I did read the manual but I find it helpless - The manual keep talking INPUT and MAIN OUTS (6CH Surround) but what about plain stereo? I am new to D-Command, I was able to hookup, messing around and now found out a problem (From me, for not fully understand the console yet, I guess), it's really basic: working in plain stereo So, What I am doing is: - My Song, I want all the tracks mix in stereo, then, I select 192 1/2 OUT. - For Monitor, I am using 2 pair of Speakers, I connect them to MAIN and ALT, both using CH 1-2. I can hear my mix fine in both MAIN and ALT... Now the Problems: - The Mono check button: Does not work, the sound is still "stereo" to me. - The Front console Headphone: I can only hear LEFT channel, the RIGHT channel will only be heard if I switch my Mix to OUT 5-6 Note that the sound from headphone is weak and a little distort... but If I assign talk back and say something, talkback sound good in stereo (while the music is still only on the left) - Please Help... Right now, i have some date line, I only want to mix so forget about the CUE, surround or stuff like that... I need The headphone to work, I want to hear it exactly what I hear in main monitor output 1/2, and the Mono check too. I suspect it's something to do with 6CH monitor so that CH1 is LEFT and CH5 is RIGHT, but Since I mix only in stereo, I have to bounce the song with output set to 1-2 ... I can't select 1-5... so, please advise what to do. I think Digi should make some tech note regarding stereo only situation, example set up or a session template... I really need help on this issue, please take a little time and help me! Thanks in advance! and sorry for posting such a newbie questions. Best regards Sonny |
Re: [D-COMMAND] HELP#2 - Stereo Monitor and Headphone
Sonny,
There are two ways to handle this. Since you're already partially up and wired this will be the quickest fix. In the I/O Setup click and drag the output of the right channel to come out of output 5. This way, you're still using Output 1-2 as your mains but they come out of the interface and therefore connect to the X Mon as 1 and 5. This is how my room is setup. |
Hi Drew,
Thanks, That solved the problem. I though about that but I was expecting a better way (D-Command preference or something), That method will require me to re-edit the output on every old session (which I am trying to avoid). The way DC handle a stereo situation is really bad, not many people doing/monitoring surround, I myself invest a surround monitor system 10 years ago but rarely use them, so the whole Genelec monitor is a waist. Digi force us to waist the whole analog I/O from 192 for just a stereo monitor, then another 8 I/O for headphone Cues ... why not no internal re-rout all the IN and OUTs. To me, This is a big dissapoinment about the DC so far You said "There are two ways to handle this" - When you have time, please tell me the other way as well (I hope it's not involve in patching signal iwith patchbay) I am very appreciate your help and input, Thanks again! Sonny |
You could use Dsub to XLR cables, that's what I do. The only thing I use the 192's analog outs for is 1 cue mix. I use the encl AES/EBU outputs into an external DAC for control room monitoring. You don't have to re-arrange the I/O setup this way.
A few things.
The other way is to simply change the wiring between the 192 and the X Mon so that 1-2 of the 192 go to X mon input 1 and 5, that's all. Even though it's a small hassle, nothing is wasted. I use all the I/O I have even when just working in stereo. My Cues and AFL/PFL use my 96I/O which leaves my 192 to be my main outs and up to six inserts (where the better converters matter). It only takes about 5 sec to drag those little blocks to convert a session. |
Hi This is probably the best idea, so my Rosetta 200 not in use now will have a good use. Thank! dmazurek! I also have 96I/O and not hook up yet, so thanks for the idea! I'll use the 96 IO for Cue 1/2 and AFL/PFL Cheers guys! Sonny |
Enjoy your D Command. Let us know how it goes.
Headphone Jack on Command 8 - can't get stereo | TDub | ProControl, Control|24, Command|8 | 1 | 03-19-2012 09:46 AM |
Monitor mix and headphone mix 192 | Raoul23 | Pro Tools 9 | 4 | 05-10-2011 11:57 AM |
Command 8's to control headphone mixs | RyanC | ProControl, Control|24, Command|8 | 0 | 10-23-2008 10:36 PM |
IS THE HEADPHONE TRS OUT ON 002 STEREO OR NOT!!!! | STAR NINE | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 02-05-2006 06:24 PM |
Quality of Command 8 headphone amp | cc1 | ProControl, Control|24, Command|8 | 2 | 03-26-2005 11:36 AM |
