#31
Re: HD Driver 2023.9 STILL Broken.
that´s important to get the 2023.3 driver working again
MP5,1 12core 3.46ghz 96GB Ultimate HDX https://www.youtube.com/channel/UCIA...Rnu0Jfh-YsgftQ |
#32
I don't understand what you mean :)
#33
I am running PT 2023.12 with HD Driver 2023.3 on the latest version of Ventura. It seems to be working fine here. Within the HD Driver DMG there is a HD Driver uninstaller that will remove the currently installed HD driver from your system. Try running it, followed by restarting your system, before installing 2023.3 again. A PRAM reset and a trashing of Pro Tools preferences can also iron things out if you are still having issues.
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command. |
#34
#35
Same deal with the HD Driver 2023.12.1. I get a false sense of hope every time.
offthewallproductions Mac Pro 5,1 3.46 Ghz 12 core, Open Core 0.9.8, Radeon RX580 GPU, GC-TITAN RIDGE TB3 PCIe card, M.2 NVMe SSD boot drive on PCIe card, 48GB RAM, macOS 12.7.4 Pro Tools Ultimate 2024.3.1/HD Driver 2023.3 HDX, UA Octo PCIe card in external TB3 chassis, MTRX Studio I/O, C|24 control surface. Genelec 1031AP/7070A 5.1 monitoring. |
#36
Yes, it's a shame, it might not be a big effort for Avid to make the HD driver compatible with 5.1... my subscription plan expired in December and I have suspended the update for now. I suspect that a lot of HDX / 5.1 users will do the same.
#37
Thanks! |
#38
It's been mentioned in this thread and others. Starting with HD Driver 2023.6 and above, an AAE Error -6001 is displayed as PT tries to Initialize the Audio Engine on startup. PT then just quits. I initially contacted Avid support back in June when this first occurred. They were unable to solve it so I started experimenting. Reverting to HD Driver 2023.3 restores normal operation with PT 2023.6/9/12/12.1. It has been mentioned by Avid reps that this is a Mojave issue but I believe that they only tested it on a Mac Pro 5,1 running the last official macOS. It seems to be some change Avid made to the HD driver for Mx processors that causes this to happen on Intel MacPro 5,1's regardless of the OS they are running. Many of us are running macOS Monterey with OpenCore on macPro 5,1's with zero issues other than this HD Driver 2023.6/9/12/12.1 error. My system details are in my sig. thx
Marker behavior broken in 2023.6 | Kevin Nettleingham | Pro Tools | 25 | 03-30-2024 09:32 AM |
PT Ultimate 2023.6 hd driver bug | kinghand | Pro Tools HDX & HD Native Systems (Mac) | 59 | 09-27-2023 05:27 AM |
2023.6 Commit Broken | NateAlexander | Pro Tools | 3 | 08-20-2023 04:24 PM |
Insert Marker Slot broken in 2023.6 | off the wall | Pro Tools | 7 | 06-09-2023 09:17 PM |
Which plug ins are broken in PT 2023.3 and why?!? | Franklyn | Pro Tools | 23 | 03-31-2023 08:07 AM |
