Old 12-28-2011, 05:04 PM
GrievousAngel GrievousAngel is offline
Default PT9.0.6 thinks its uninstalled!
Hello All,
For some reason, PT now thinks it is uninstalled or either another program is controlling it.
Any ideas how and why this happens? I am running W7 64 with SP1 installed and using LYNX AES16e audio interface.
Suggestions please.
Thanks,
William
GrievousAngel
Statesboro, USA
Old 12-28-2011, 06:15 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: PT9.0.6 thinks its uninstalled!
What's the exact error message you're getting?
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 12-29-2011, 10:17 AM
'ProTools hardware is either not installed or used by another program.' No error code number.
GrievousAngel
Statesboro, USA
Old 12-29-2011, 05:14 PM
zedhed's Avatar
zedhed zedhed is offline
Do you have another program opened at the same time as Pro Tools, such as iTunes?
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Old 12-30-2011, 07:30 AM
No, not opened, but installed.
William
GrievousAngel
Statesboro, USA
Old 12-30-2011, 08:01 AM
YYR123's Avatar
YYR123 YYR123 is offline
Default
Will, check the general troubleshooting guide at the top of the ProTools 9 section
I was looking through there yesterday for some of my own issues and I'm positive I saw two threads of the same exact issue you were having.
At least they were two threads describing the same problem about hardware in use by another program, or what ever it was
Check it out
Daniel
Old 12-30-2011, 09:16 AM
EGS's Avatar
EGS EGS is offline
Originally Posted by GrievousAngel View Post
...Suggestions please...
1. Do each and every one of the Avid suggested system optimizations. Each and every one. You may have missed one or more of them:
http://avid.custkb.com/avid/app/self...p?DocId=367983
2. Make sure each and every one of your plugs are the latest versions. You may have missed one or more of them:
http://avid.custkb.com/avid/app/self...p?DocId=343311
3. Do each and every thing suggested here, too. You may have missed one or more of them:
http://duc.avid.com/showthread.php?t=300050
4. When you do solve the issue, take an Acronis image. Take another Acronis Image every time you make a change to your C drive, like installing something or tweaking something:
http://www.acronis.com/homecomputing...cts/trueimage/
While this all may seem like a lot of fussing around, the good news is that you will eventually fix your rig and be good to go.
Hope this helps !!!
Click for audio/video demo
Click for resume
Old 12-30-2011, 02:32 PM
EGS,
Thanks for the detailed suggestions. I do them now. I have done a few already.
Later, William
GrievousAngel
Statesboro, USA
Old 12-30-2011, 06:14 PM
cwsand's Avatar
Hope this helps !!!
Great ideas - you might want to go into msconfig and disable all background programs and reboot. Could be one of those causing the conflict.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
Slate Digital VRS8
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
[IMG] code is Off
Reinstalling PT v9 after having uninstalled it. AncientMan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-27-2011 09:18 AM
Uninstalled ProTools LE7.4 to upgrade to 8.0 now nothing TJW 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 01-03-2010 11:09 AM
uninstalled, reinstalled and got this messgae!! thirdrailproductions 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-27-2006 05:03 AM
soundblaster uninstalled illone 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-08-2006 08:49 AM
How to get rid of uninstalled plugins in PT 6.4 le shynomi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-25-2004 08:59 AM
