Old 04-10-2016, 06:54 PM
basslik's Avatar
basslik basslik is offline
Default Digi 003 /lock PCM90
Hi everyone, hope all the tracks are gelling.
I can't get my PCM90 to lock up with my Digi 003 console. If even posible, what I'm trying to do is SPDIF out as a insert, and SPDIF back in?, I can do it analog out of the DIGI, and then SPDIF back in no problem.
A MILLION THANKS.
MAC PRO 2010 5,1 3.46hex 96ram - Mt. Lion 10.8.5 - PT 9.O.6 003 CONSOLE /DIGIMAX FS /PCM90 2CHANNEL SPDIF
Old 04-10-2016, 07:46 PM
Default Re: Digi 003 /lock PCM90
Hmmm, it SHOULD be able to work. With SPDIF cables in both directions, You need to do 2 things; 1 decide which device will be the master, and 2, make certain to match the sample rates of the session and the Lex(assuming the Lex is the master clock). It would likely be easiest to leave Pro Tools on internal clock and set the Lex to sync to SPDIF, but you should try letting the Lex be master and see if you can hear a difference. In any case, remember that the Lex probably defaults to analog IO, so check its utility menu to enable the digital IO(shooting from the hip here, but this worked for me with 003 and a TC M-ONE)
Old 04-10-2016, 08:19 PM
basslik's Avatar
albee1952, your tremendous always lending in a blink of an eye.
Sample rate same, will check which is master.
Old 04-11-2016, 01:21 AM
JFreak's Avatar
JFreak JFreak is offline
003 should be the master. you can see it in hardware setup, if it says clock is internal then that's it.
PCM90 needs to lock to that clock you send via SPDIF so check those menus where you see clocking and set it to external
Janne
Old 04-11-2016, 08:44 AM
john1192 john1192 is offline
does the PCM90 only do Digital at 44.1k ??? if so, unless your session is at 441.k you will need to use analog .. no one will know !!! and we won't tell anyone ..
OS 10.12.6 for PT 11.3.2 & 12.4 & above
Mac Pro 6-core 3.33ghz (2012) 24gb ram 256gb SSD
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS10.12.6 - PT 12.4 & above
lynx AES16e-SRC & Aurora 16
Artist Transport & iPad - Pro |Control - EuCon 3.7 (older Euphonix Branded MC Transport)
Old 04-11-2016, 09:33 AM
JFreak's Avatar
This document says 44.1k and 48k (and should address all other questions too)
Janne
Digi 002 Faders Lock Keniko 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-15-2006 08:51 AM
Digi Feature Request - Transport Lock Andre Knecht Pro Tools TDM Systems (Mac) 1 06-16-2005 08:53 AM
Lexicon PCM90 for R&B Vox? nd General Discussion 7 09-14-2002 05:20 AM
Digi 001 and Logic 4.5 won't lock up rope 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-14-2000 06:57 AM
USD lock to NAGRA, Digi? COCO Tips & Tricks 5 05-20-2000 04:27 PM
