Old 04-05-2016, 03:26 PM
fweiss fweiss is offline
Default PT 8LE Configuration-- can it be saved (new OS issue)
My husband has PT 8 LE running on a Macbook Pro (2011). We upgraded his OS to El Capitain for something and his PT 8LE is no longer compatible. He had the Lion OS before. I know, I know-- big mistake.
If we restore Lion (which is possible), do we lose his configuration in PT 8 (ie: how the inputs and outputs set up, the templates, the internal clock setting, etc)? If this is the case is there a way to save or restore his old PT 8 LE configuration/settings?
I've already discovered from reading the forum that we cannot upgrade PT 8 to 12.... And I gather from this forum that PT 12 is the only version that's compatible with El Capitain. So I feel our best best is returning to the Lion OS.
Any suggestions or solutions are welcome. I would be eternally grateful. It took my husband 3 months to get his set-up right; I want to see if it can be salvaged. I unwittingly messed up his system.
Old 04-05-2016, 03:43 PM
john1192 john1192 is offline
Default Re: PT 8LE Configuration-- can it be saved (new OS issue)
where is your husbands backup drive that has his entire system on it that he worked so hard to build ?? use that ..
OS 10.12.6 for PT 11.3.2 & 12.4 & above
Mac Pro 6-core 3.33ghz (2012) 24gb ram 256gb SSD
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS10.12.6 - PT 12.4 & above
lynx AES16e-SRC & Aurora 16
Artist Transport & iPad - Pro |Control - EuCon 3.7 (older Euphonix Branded MC Transport)
Old 04-05-2016, 03:57 PM
I don't know that he has that.... He saved the audio files he made. To my knowledge, he didn't back up anything having to do with his configuration. Presumably it's still with PT8 LE, which he still technically has on his machine. So I'm wondering if it can be restored, moved... or the settings somehow carried over.
Pro Tools 10 Student Version- To upgrade, or not to upgrade? KFPCalvin Windows 4 04-12-2012 08:37 AM
Upgrade to Pro Tools 8 (with upgrade dvd) asking for Auth code? (HELP) Mista808 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-12-2010 01:40 PM
Upgrade question - can I use mbox2 micro upgrade on 002 system? spreston 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-22-2009 11:22 AM
Upgrade link 'Sorry, no product found.' How can I upgrade?? dim 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-15-2008 12:44 AM
5.1 upgrade..drivers? also is the D-verb demo an upgrade? bryanbassett 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-21-2002 11:46 AM
