System reboot resets digital i/o setup
Everytime I reboot my system the i/o setup changes from however I have it set to some default which is not what I want. I am running a digital desk and whenever I restart my i/o's are set mostly analog. quite frustrating.
oh yeah, my playback engine resorts to a previous setting as well. I am on OS 9.2 and pt 5.3.1 any suggestions? |
Re: System reboot resets digital i/o setup
I have had this happen to me a lot to in OSX and PT6.1 have not figured out why it does that.
Mac 8 Core 6,1 - OSX 10.13.6 - 32GB RAM - Pro Tools 2018.10 - 8x8x8+8 ch DA Card (x2) - HD OMNI - ICON D-Control 32 - Sync I/O - Sonnet xMac Pro Server w/HDX x 2, Blackmagic Intensity Pro 4K Protools 2018.10 HD Native in 1 project suite Eristopher Music |
I had this and I trashed prefs and it went away.
i tried trashing prefs. still, everytime i reboot my system the i/o setup is changed and the playbakc engine as well.
go into i/o setup design and label your i/o/inserts/busses the way you want @ the same time, export your settings and name it. save & close session! open new session, it should open up with the new i/osettings you gave last session. If this does not work then when you open new session it will ask for i/o setup>>>>>>>>>point this to the new setup you made previously! If you are opening up a session from another source ot studio then do so as normal then go into i/o setups and import your setup that you made previously and yes discard old i/o's when prompted! This is assuming that you are using HD..........hope something helps
Post back!!! |
My I/O labels and paths are loaded properly each time i reboot, it is the settings of the interfaces - digital vs analog input/output that continues to reset incorrectly as well as playback engine. RAR!
peter wade |
Protools looses after reboot the Midi setup | 0815marta | Pro Tools 11 | 0 | 03-02-2014 06:40 AM |
002 Causing System to Reboot | Kevin Genus | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 08-13-2004 07:38 PM |
PT resets hardware setup | ctmartin | Pro Tools TDM Systems (Mac) | 1 | 08-12-2002 06:11 AM |
5.3.1 causes system reboot when loading | ArchieGates | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 07-29-2002 10:18 AM |
Sound Output resets to "Built-in" on every reboot | Gremz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 04-12-2001 12:43 AM |
