Old 08-28-2002, 04:53 AM
Nick Le Mon Nick Le Mon is offline
Default D-subs to C24
At present all my 192's analogue outs are all going into the C24 via a D-sub.
As I'm not really using 5.1 at the moment I want to be able to use some of the outs (4) to go to other outboard.
Has anyone split a D-sub out into another d-sub carrying four and four separate xlr cables?
If so,will the C24 still carry the Aux outs ok, or does the C24 need all eight channels going into the back.
Cheers
Nick
Old 08-28-2002, 09:54 AM
Jan Folkson Jan Folkson is offline
Default Re: D-subs to C24
They're just analog audio connectors. You can split them any way you like, just be sure to pin them correctly.
- Jan Folkson
www.janfolkson.com
Old 08-29-2002, 12:38 AM
R SCHLESINGER R SCHLESINGER is offline
Nick,
Jan is correct. However, if you are planning on Y-ing off of a D-sub connector, I hope you have some talent, and if so I could probably use you.
I would recommend a patchbay. Regardless of what path you take, if you need help or need the cable and/or patchbay, I'll hook you up.(pun unintended)
RADAR
C24 D-subs chainboy ICON & C|24 1 01-14-2007 04:04 AM
OT: Subs Kris75 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 02-25-2006 01:40 PM
Reason on subs to record l'Andrew 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 11-11-2003 08:10 AM
OT - Cheap subs? Sparky1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 08-21-2003 06:32 AM
Subs & Scrubs (need a HPF) John McDaniel Pro Tools TDM Systems (Mac) 0 12-18-2001 11:14 AM
