Re: Intermittent fader jiggle
Sounds like you might need to call Customer Service for that one. I've used several C/24s and none of them exhibited that behavior.
HTH. |
Has anyone else had this problem? For no apparent reason, even if automation is disabled, a single fader will move, or jiggle, without any rhyme or reason. This also seems to happen when I'm using fader automation.
The only time it doesn't occur is if I have only a few tracks in the session, say six or less. The culprit fader varies but is usually around 12-14. I've only had this happen with two faders at the same time, usually it's a single. If you have any ideas, they would be much appreciated! Regards, Rex
PT 7.3.1cs5, HD3 192 I/O, Control|24 2GHz G5, 2.56G ram OS 10.4.11 |
10.3 and 10.3.1 Small Volume Fader AND Clip Gain Fader Problem | Ale | macOS | 1 | 10-11-2012 10:07 AM |
Basic Gain Structure Fader/Master Fader Question | acmost | Pro Tools TDM Systems (Mac) | 1 | 05-16-2011 05:36 AM |
FADER MUD - IMPOSSIBLE TO MAKE FADER WRITES IN REAL TIME | Jim Casey | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 04-22-2007 10:34 AM |
'Fader Pack' and ProControl Fader order issue | Ciaran | ProControl, Control|24, Command|8 | 2 | 03-21-2005 11:58 PM |
DIGI: Will it ever be possible to implement Pre-Fader Inserts on the Master Fader? | Ricky Cobble | Pro Tools TDM Systems (Mac) | 5 | 05-05-2003 04:47 AM |
