Headphones with Control 24... TALKBACK!
Hey again,
how does one setup headphone mixes with the control 24 that allow you to use the integrated "Talk back" feature? Thanks, Jon |
Re: Headphones with Control 24... TALKBACK!
aux out - headphone amp
monitor to aux button they describe it pretty well in the manual. dan |
Nutshell's method will work if you want to feed the artist the control room mix, but if you want to create a separate cue mix here's how you do it.
1. Send two outputs from your i/o to the AUX INs on your C/24 (I use 23-24). 2. Assign a send on each channel to the same pair of outs that you set up in step 1. 3. Usually I copy the mix to the send as a starting point. This can be accomplished using the 'copy to send' feature in PT. 4. You'll need to send the AUX OUTs to a headphone amp and connect your cue system accordingly. 5. The talkback will work with both this method and Nutshell's. HTH. |
artist control and talkback with PT 10 | jakertanner | Artist Series | 4 | 09-13-2013 11:14 AM |
Pro Control Talkback switch | GrantFM | ProControl, Control|24, Command|8 | 0 | 12-02-2009 11:44 AM |
pro control, surround, talkback and cue mix | StaticStudios | Post - Surround - Video | 4 | 11-17-2007 06:18 PM |
Control 24 Talkback problems | CraigLearmont | Pro Tools TDM Systems (Mac) | 3 | 09-23-2005 07:47 AM |
Talkback mic on the control 24..How to.. | trelobas | ICON & C|24 | 2 | 08-29-2003 09:44 AM |
