Buzzing in left monitor speaker
we have 6 Control24 at my work and at least two of them have the same problem. a buzzing develops in the left monitor channel and the signal level drops considerably. i need help with this soon as our warranty is about to run out. is this the fabled power supply problem?? or something else?? |
Re: Buzzing in left monitor speaker
WHEN YOU SAY IT DROPS IN LEVEL, DOES IT DROP 6dB
OR IS ONE SIDE TWICE AS LOUD HAVES YOU CHECKED YOUR CABLES/GROUNDING |
Call em quick.
Had same problem - got a new one. hope this helps dan |
i think the level drops around 6dB. but the buzzing in the monitor is totally oppressive.
do i get straight to digi for a replacement or do i go through my dealer. |
sounds like the exact same problem i had. it ended up being a monitor power supply. call digi and get new ones. i got mine 16 hours after i called. good luck.
CALL DIGI ASAP AND YOU SHOULD BE OK IF YOU ARE UNDER WARRANTY! good luck dan |
Sound only coming out of left speaker | chrisshack89 | Windows | 5 | 05-29-2013 12:35 AM |
Only left speaker works | benzclk1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 07-02-2009 01:48 PM |
c/24 no sound in left speaker out | raga2000 | ProControl, Control|24, Command|8 | 2 | 06-04-2007 02:11 PM |
Left Speaker Only | tsewards | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 12-04-2006 06:24 PM |
Only getting output from the left speaker | Bus 7-8 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-09-2004 07:00 PM |
