Old 11-08-2022, 10:59 AM
bifbangpow bifbangpow is offline
Default Video Engine quit unexpectedly
Keep getting this error when I playback video. Scoring a short and getting this error.
running PT 2020.12
Mac OS Catalina
iMac Retina 5k 27" 2020
I'm sure someone else has solved this but I couldn't find it in search.
my specs:
iMac 2020
3.8Ghz 8-core Intel core i7 processor
Catalina OS
ProTools 2020.12
Scarlett Focusrite
+ Saving to External Harddrive
http://MayMcDonoughMusic.com
Old 11-08-2022, 11:19 AM
Eric Lambert's Avatar
Default Re: Video Engine quit unexpectedly
It's not unexpected, unfortunately. Though FAR less prevalent than it was in past years, the engine does quit from time to time. I work w/ video files most of the time and still get the error about once every other week.
I can tell you that it seems to be somewhat dependant upon the type of video file; less-typical CODECs will cause the error more often than common CODECs. In the past we've had to convert (by exporting) "dirty" video files to something more common that PT likes. That's right, PT doesn't like dirty videos.
To be honest, I've never found anything that will cause this every time. It's unpredictable. It should say Video Engine Quit Unpredictably.
Old 11-08-2022, 11:20 AM
its2loud its2loud is offline
What version of Catalina?
Here's some compatibility info..
https://avid.secure.force.com/pkb/ar...2-Release-Info
Check your video format. if you're working in h.264, stop working in that format and convert to DNXHD.
Old 11-08-2022, 12:47 PM
LOL.
my specs:
iMac 2020
Catalina OS
ProTools 2020.12
Scarlett Focusrite
Old 11-08-2022, 09:43 PM
I receive and use H.264 vids all the time. I'm not suggesting the format, just stating that they're common.
Now, it's possible that those occasional issues I mentioned are due to this CODEC, but I don't think that's the case. FWIW, I'm previewing video via a TV connected to the Mac's HDMI output -- no external video converter. When I used a Blackmagic box there were just as many issues, but that was years ago and PT was (likely) to blame for those errors.
quit unexpectedly with 10.3.3 Brandonn Pro Tools 10 4 02-14-2013 05:19 AM
Help! - unexpectedly quit ErockVillage 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-07-2009 11:56 AM
Unexpectedly quit?! GinGin3 Pro Tools M-Powered (Mac) 6 09-01-2007 11:30 AM
Unexpectedly quit Han Nuijten Pro Tools TDM Systems (Mac) 2 01-19-2006 08:48 AM
PT unexpectedly Quit MarkPresti 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-11-2003 09:38 AM
