Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 09-20-2021, 09:56 AM
soundboy35 soundboy35 is offline
Default Pro Tools hangs with Behringer x18 as the USB interface
I'm running PT 20.9.1.123 with an X18 as the USB interface, on Mojave 10.14.6
I'm having issues, specifically when launching/quitting Pro Tools. Pro Tools will hang indefinitely on launch and when quitting.
Is there a specific launch/quit order when using the X18 as an interface as far as which is launched/quit first? I seem to have better luck when launching PT, then launching the XAir app to sync the X18.
The X18 is connected USB and Ethernet to my Mac, in order to run the XAir app. I'm not using an iPad etc, to control the XAir app, so it's all controlled through the Mac.
Anyone else having this issue? I don't know if the issue is USB related or?
MacBook Pro 15in, 2.3gHz,i7
PT 2021.x
PT12.8.x
Old 09-20-2021, 10:10 AM
jeam25's Avatar
jeam25 jeam25 is offline
Default Re: Pro Tools hangs with Behringer x18 as the USB interface
Hi i see that there is no USB oem driver on the mac side for that interface . So maybe a configuration problem ? How mac see the interface ? It is on the aggregate devices list ?
Maybe trying with aggregate and alone ( if possible ) Also , this thing happen using the built in audio as PT playback or just with the berhinger ?
Sent from my SM-G991U using Tapatalk
Mac M1 Studio Ultra - Sonoma Beta OS
Avid Carbon Interface
Protools Ultimate
Old 09-20-2021, 10:28 AM
The X18 does show up in the Playback Engine list. I've only noticed the hang issue with the X18. I've set the default system audio to Internal Speakers.
I can try setting the PBE as Built In and Aggregate and see what happens, but I believe the hang only occurs when the X18 is the PBE device
PT 2021.x
PT12.8.x
Old 09-20-2021, 01:38 PM
I've been able to narrow it down to the external router (which connects to the X18 only) as the issue. It's using the same IP address as the cable modem for some reason?
I'm not using an iLok cloud license or cloud storage/cloud collaboration?
PT 2021.x
PT12.8.x
Old 12-31-2021, 11:35 PM
Osiagh Osiagh is offline
Hey, I’m having the same issue same setup. Any solutions yet?
Old 12-31-2021, 11:41 PM
Is it a matter of going to the setup preferences and setting the IP to another path that doesn’t block communication with PT?
Sorry if my question didn’t make sense. I’m having trouble figuring it out.
Old 01-01-2022, 08:36 AM
I agree that changing the IP is worth a try. Also, make sure the interface(X18) is connected and turned on BEFORE you boot the computer(also worth trying anyway if you are not already doing this)
Pro Tools hangs mightyduck Pro Tools HDX & HD Native Systems (Mac) 5 01-12-2018 04:37 AM
Setting up with Behringer XR18 Interface Jamiesjammin Pro Tools 12 6 11-15-2017 07:03 AM
Using Behringer USB mic with pro tools ANBUACHALL Pro Tools 12 1 10-17-2016 06:30 AM
controling PT with a BEHRINGER BCF2000 interface fxrobert Pro Tools M-Powered (Mac) 5 05-24-2006 08:30 PM
behringer mx9000,behringer mx3282A,mackie 24/8buss JOAN ROSALES 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-03-2004 12:21 AM
