Fades in 12.7 wiered
Dear all,
can someone confirm the behavior of fades? In "old times" (pt.11.3) I could just cut the tail of a clip and it was gone including the fades. Now the fades jump to the left to the new ending of the clip and messing around there. This does not happen at the top of a clip. The option "preserve fades..." is switched OFF. Toggling it does not change anything in this behavior. IF this feature "preserve fades" would work how intended (looks like a bug here for me) it would be just grat to have it in the OPTIONS menu in order to give it a shortcut through macOS. Do I miss another setting or is it a bug here? Cheers, Markus |
Re: Fades in 12.7 wiered
cheers john
Oh, I am sorry...
OSX 10.10.5 MacPro 5,1 12cr 32GbRam PT12.7.0 HD no DSP Same Session in 11.3.2 on the same Comp work normaly. |
corrupted session maybe ??? does it happen in a fresh session made in 12.7 ?? or just from older sessions ??
I have seen the same issue. It doesn't happen all the time but when it does it seems to always be at the end of a clip.
If I select the area and choose delete fades from the menu, then it deletes it. I also have the "preserve fades" option off. PT HD 12.7 Mac OS 10.12.2 Mac Book Pro (Mid-2015) Quote:
I have seen this too.
12.7 Sierra 10.12.2 MBP (but happened in Yosemite too) and Win 10 Not a game changer, but annoying.
Digi002R PT2018 Win 10 INTEL Core i7 930, 3.52 Ghz GIGABYTE GA-X58A-UD3R CORSAIR XMS3 12GB 1600Mhz 2 X WD 1TB Caviar Black 64 GB cache MOTU Traveller PT2018 MacBook Pro Mojave 16GB DDR3 |
Loud White noise fades on fades and dissolves! | www | Pro Tools 9 | 2 | 04-16-2013 09:59 AM |
Replace all fades with dithered fades | BScout | Pro Tools TDM Systems (Mac) | 0 | 10-31-2009 03:32 AM |
Fades prefs vs. Batch Fades (or beating a dead horse) | Starcrash | Post - Surround - Video | 2 | 09-23-2008 03:40 PM |
create fades batch fades issue pt le | theom | Tips & Tricks | 4 | 07-24-2006 09:46 PM |
fades on muted regions render active fades?! yikes | clarpark | Pro Tools TDM Systems (Mac) | 11 | 02-08-2004 04:49 PM |
