Old 03-08-2016, 08:18 AM
Tim R. Tim R. is offline
Default MOV from iPhone won't play in sync in PTs
I recorded a 22 minute video on my iPhone (6Plus) set at 1080p/30fps (QT Inspector shows Format: 1920X1080 AAC 44.1 mono 29.98FPS). When I import this MOV (with audio) into Protools the video plays back out of sync with the associated audio (that came from the MOV itself). I'm finding a fair amount of discussion on the issues with H.264 files. Just wondering what the best standard practice is to get the video to play accurately in Pro Tools? If converting to another format is the solution, what do people use for the conversion?
Puzzling to me is that I get H.264 videos from Media Composer regularly for my post work that play fine in Pro Tools.
Tim Reisig
Main System: Pro Tools Ultimate 23.12, HD Native TB, HD OMNI, S3/Artist Transport/Eucontrol 22.20, Apogee Rosetta 800 w/XHD card, Avid 96 I/O
Mac OS 13.2.1, 2018 Mac Mini 3Ghz i5, 32Gig RAM
System 2: Pro Tools 23.9 (no Hardware), Mac OS 13.2.1, MBP (Macbook Air M2, 2022 24Gig Ram)
Old 03-08-2016, 10:49 AM
Marcel Risberg's Avatar
Marcel Risberg Marcel Risberg is offline
Default Re: MOV from iPhone won't play in sync in PTs
I've heard something about the Apple/iOS interpretation of "30 fps" is in fact not at all what the rest of the world call 30fps. (I believe Russ from the Pro Tools Expert team has mentioned it on the podcast. Something like 30.1 fps - but I could be remembering that wrong.) If you find something meaningful about this, please update this thread about it. I'd also like to know.
Marcel Risberg
Production sound and audio post - ljuddesign.se
Enthusiastically sharing knowledge and experience at Stockholm Film School.
🛠 Pro Tools Ultimate 2019.10 · HD Native · HD Omni
🎚 EuControl x.x.x · Artist Control · Mix · Control App
🦑 MacPro5,1 · 12C24T @3.46GHz · 48GB · SSDs · macOS 10.13.6 (17G5019)
📺 Separate video playback machine
🥇 Covered by ZDT/TLC · Keeping DAW OS clutter free
Old 03-09-2016, 06:53 PM
Sonny Keyes Sonny Keyes is offline
I remember reading a thread about this on an Apple user board; apparently the iPhone records video at various frame rates depending on the lighting conditions - the brighter the shot, the higher the frame rate. (!) The fix is to import the video into iMovie and export it again at the desired frame rate, which will be stable.
Sonny Keyes
Toronto
http://www.sonnykeyes.ca
Rig 1: 2.8GHz Macbook Pro PT 12.7.1 Logic 10.3.2 Scarlett 18i20
Rig 2: 2.66 QuadCore Intel Xeon Logic 10.2.0 Scarlett 18i20 PTHD10.3.10
Old 03-10-2016, 09:00 AM
john1192 john1192 is offline
when playing your iPhone movie in QT (QT 7 preferably) and open the Inspector .. it will show your frame rate in realtime .. does it fluctuate .. ???
i just watch a movie i shot with Canon 5D shot at 23.98 Qt7 show 24 frames ..
very curious to hear what you find .. which iPhone version was used ???
cheers john
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 03-10-2016, 11:28 AM
cheers john
As I mentioned, here's my file info: Shot on iPhone (6Plus), iOS 9.2.1, set at 1080p/30fps (QT Inspector shows Format: 1920X1080 AAC 44.1 mono 29.98FPS)" The framerate does not appear to fluctuate when playing in QT player. It is also a totally static shot of an orchestra conductor for about 25 minutes.
Tim Reisig
Old 03-10-2016, 11:38 AM
i would expect it to say 29.97 (not 29.98) ... that is odd ... have you tried the imovie or QT conversion to see if it helps ??
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 03-10-2016, 08:52 PM
I've tried exporting from QT player to 1080P before importing to PTs but that didn't help. Next I'll try exporting from iMovie. I'm just hoping to NOT lose too much quality in the transcoding just to get the damn thing to play in Pro Tools. As I said, the end product has to be "Bounced to move" from Pro Tools so I'm stuck with that file format as an end product.
Tim Reisig
Old 03-11-2016, 03:57 AM
Kuba Pietrzak Kuba Pietrzak is offline
I did a sound post-production for a short recorded with an iPhone. And I would say, the frame rate iphone uses for capturing video (and audio) is really strange (I do not remeber the exact number of fps). We ended up with transcoding all recorded material to 25fps and then did the video edit and audio post for it.
To my best knowledge, a direct import a iPhone video into ProTools will not work.
Kuba
Old 03-11-2016, 05:49 AM
Kuba
Thanks Kuba, I suspected this to be the case. What did you (and others) use for the transcode? And what settings/format maintain the quality while creating compatibility?
Tim Reisig
Old 03-11-2016, 07:30 AM
As I remember, Avid Media Composer was used. But I was not involved in the exact process (a machine room guy did it), so I cannot give you more details.
This was 1second = 1second method, so the actual speed of sound wasn't changed.
Kuba
HTML code is On
Issues with iPhone Tapatalk iPhone client stevedemena General Discussion 0 06-21-2012 02:54 AM
Is it possible to play a click without pressing play, and have it in sync.... ALowe macOS 5 06-05-2011 04:24 PM
Newly recorded tracks play out of sync Kourquie Pro Tools TDM Systems (Mac) 1 07-13-2009 04:57 PM
spot sync point in digibase pro region display to play head willco Post - Surround - Video 1 01-04-2009 03:25 PM
Which Pro-tools version can sync up with a DV play jarvis-10264 Pro Tools TDM Systems (Mac) 7 11-23-2004 07:10 AM
