2009 Mac Pro GUI Issues?
Hey I just got myself a:
2009 MacPro 4,1 - Two x 2.93 GHz Quad Core 45-nm Xeon X5570 64 GB of RAM 1TB mSata Samsung SSD The mSATA SSD is on a Addonics Quad mSATA PCIe SSD - http://www.addonics.com/products/ad4mspx2-a.php 12TB RAID 0 made with Two 6TB Seagate 7200RPM Drives It seems to have a GUI lag in Pro Tools 12. I've tried the Quartz Debug trick but that hasn't really worked out perfectly either. Pro Tools 10 seems to not have an issue compared to 12.4. I've tried 2 different graphics cards: NVidia GTX 770 2GB http://www.macvidcards.com/store/p9/..._and_4_GB.html and Sapphire HD 7950 http://eshop.macsales.com/item/Sapphire/100352MAC/ The Sapphire has been a little better but still kind of glitchy. I've tried running the sessions off of the Software 12TB RAID drives as well as the mSATA SSD. I can still return this computer just FYI. Thanks in advanced. |
Re: 2009 Mac Pro GUI Issues?
I recently found out that all of the 4,1 mac pros are not compatible with ProTools 12. This information came from a reply to a support case that I raised bfore Christmas, and I confirmed it with the compatibility PDF document. 4,1 is not on the list.
Do you mind sharing the PDF? Thanks for your help.
They may not support it that doesn't mean they don't work. The GUI issue effects lots of users across many macs, macbookpro, new Mac Pro, 2010 Mac or, iMac etc. it's an issue with PT12 and OS X El Cap. Quartz debug only helped with Yosemites graphic issues they changed it for El Cap. You can upgrade the 2009 4,1 to a 2010 5,1 with firmware update with Supported westmere Xeon 5600 series processors.
I did with mine. The graphics bug is not because you have a 2009. Don't sell a perfectly good machine, you can upgrade it and have a very fast beast. As many of us here have. Hopefully Avid will get their shoit together with this annoying graphics bug. 10.11.2 is worse than 10.11.1 and is not supported by Avid yet.
Mac Pro 5,1 12 core 3.46ghz OS X 12.6.1 Opencore 0.8.6 Pro Tools Ultimate 2022.10 Mac Pro 2009 upgraded to 5,1 12 core 3.46ghz GPU RX6800XT, Samsung 970 EVO Plus pcie boot drive, Titan Ridge flashed for Mac. Midas M32r console. iPad Pro with Avid Control |
Apple Mac Pro 2.93GHz 12-Core "2010-12" with 16GB DDR3, 1.0TB 7200RPM HDD, SuperDrive, Radeon 5770 I'm gonna try this one and then see which one works better and then return one or both depending on how they work. I'll try the other GPU's I have as well as the 64GB of RAM and the 12TB Software RAID drives i have. I should also add I am using Mavericks 10.9 |
I know my sig shows I am running a Windows machine but I also own a 2009 Mac Pro 4.1 two processor 2.93 (8cores) with a 5770 graphics card just like the first one you tried. I pulled my hair out trying all the things you did including the patch for the graphics card. After all that I found it was the Apple drivers causing the problem all along even with the patch installed. I purchased Mac OS 10.8.5 from Apple by calling their support folks and installed it from scratch and have not had a graphics problem since then. Version 10.8.5 is the only one you will be able to use without problems on this machine b
Pro Tools Ultimate 2023.9. Mac Studio M2 128GB Ram 24 Cores 4 TB HDD. 2 Universal Audio Satellites. Lynx Aurora N. |
If you're already upgrading, i strongly suggest upgrading your CPU's to 12 core. I can walk you through it if you are interested.
HD Native Pcie, PTHD 11, PT12 Vanilla, Omni, Lynx Aurora 16, 192 I/O (16 in/8 out), 24 Fader D-Command, lots of preamps and compressors. MacPro 5.1 (12) Core (2009 MacPro 8 Core Upgraded to a 12 Core MacPro), 56 Gig Ram, SSD System & 3 - 2TB Drives, OSX 10.9.5, Windows 10 Via Bootcamp |
11.3.2 on 2009 imac with 10.10.5 | suirthing | Pro Tools 11 | 2 | 01-22-2016 12:36 AM |
mini late 2009 issues | Indy rev | macOS | 4 | 12-16-2014 03:31 PM |
PT LE 10.3.8 and Mac Pro 2009 performance issues | seanleclair | macOS | 3 | 02-17-2014 03:15 AM |
2009 Quad or 2009 8-Core Nehalem? | psmworld | Pro Tools TDM Systems (Mac) | 8 | 04-08-2010 03:18 AM |
So..after Dic. 19th 2009 | Pedro perez | Pro Tools TDM Systems (Mac) | 6 | 11-27-2009 07:42 AM |
