How do I launch co-install of PT10?
What am I missing?
I've installed and am successfully running PT 11.0.2 on my MacBook Pro 10.7.5 but I absolutely cannot find any information regarding how to launch PT 10. I understand PT10 was included with my install of PT11, but searching on my computer yields no results for it. There's only one app icon and it's for PT11. It's also one of those tricky search terms which is tough to find info on through the googles. Could I have missed a step with the install and only installed PT11? How would I then reinstall PT10? Going back to Avad.com/activation and entering my activation code says I can only download once. **UPDATE** - Downloaded separate 10.3.8 installer and PT10 crashed on launch. So I moved plugins to the 'Unused' folder and 10 launched. Moved plugins back to the 'Used' folder, and it still works. Last edited by touch; 01-03-2014 at 09:21 AM. |
Re: How do I launch co-install of PT10?
Hi
PT10 is a separate installer and can be found under your Avid Account. Look under View My Products and there you can download PT10 and you also need to install a separate instrument and plugin file you also have in your account called 10.3 and is approx 2.6-2.7GB. Contains virtual instruments and AIR plugins. Remember to install the latest version of PT = 10.3.8 Best Of Luck Christopher
Thanks Christopher. I found it and installed PT10, but it crashes on launch. This is the error report:
Hi
I am on it, asking a few guys here who knows more about crash reports for MAC so hang in there and we will get back to you Christopher
PT10.3.8 is still crashing on launch. "Pro Tools quit unexpectedly"
Do I need to uninstall PT11 before installing 10? What I'm reading leads me to believe this is not necessary. |
I finally got it to launch. I moved all the plug-in's into the 'Unused' folder, and it started working. Then I started adding them back into the 'Used' folder. When I got to the end and they were all back in there it still works. Go figure...
Cheers! |
You should check the docs, looks like Lion is not supported for PT11 or the co-install
http://avid.force.com/pkb/articles/e...m-Requirements
MacBook Pro 15in, 2.3gHz,i7 PT 2021.x PT12.8.x |
The first thing that comes to mind for me is that the 4GB RAM limit in the 32-bit Pro Tools 10 application can cause Pro Tools to run out of memory when 1st loading a lot of plug-ins. The solution you mentioned would work, and what I have had work in the past is relaunching until the plug-ins database has been completed.
Bruce, I've had exactly the same. Just persevering and relaunching PT10 after it fails is the solution.
When you watch the progress of plugins being scanned, as shown on the splash screen, it gets further each time. Eventually, in my case after 4 relaunches, it gets all the way through the scan. After that, no problems launching subsequently. I've had that with every iteration of PT10 for a while, just got used to it whenever a new version of PT10.x cones out.
Mac Pro 2009 with 2010 firmware, 12-Core 3.46ghz, 64gb RAM & working Thunderbolt, OS 10.14.6 and Windows 10 iMac 2012 27", 3.4ghz i7, 32gb RAM OS 10.14.6 Digi 003 Console for control surface only, Focusrite OctopreLE and MOTU Traveler for extra analog-ADAT conversion, UAD Apollo Quad Silver with Thunderbolt card, Apollo x4 and pci-e Octo, Adam A77X monitors. Pro Tools 2022.4, Media Composer 8.9, Sibelius 8.7, Cubase Pro 11, Wavelab Pro 11, Logic Pro X 10.5.1, Mainstage 3. Various apps, soft synths, FX plugins. Plenty of hardware synths, rack gear, microphones etc. And then there's the studio ;-) |
PT10.3.8/PT11.1.1 launch issues... | cwhite771 | macOS | 16 | 06-27-2014 06:30 AM |
Co-Install PT11/10.3.8 - Can't launch PT10 - Help | kentuckyben | macOS | 2 | 01-07-2014 02:18 PM |
my new pt10 wont launch... | evoyzey | Pro Tools 10 | 15 | 12-27-2012 12:22 PM |
PT10 upgrade won't launch in HD | seafra | macOS | 3 | 11-09-2012 07:06 PM |
West Aussie PT10 launch | Draulym | Pro Tools 10 | 3 | 11-14-2011 10:29 PM |
