Old 07-28-2011, 11:11 AM
lexaudio lexaudio is offline
Default Can't change Automation modes with Control
Can't seem to figure out why I can't change the automation mode of a track in PT9.
According to manual:
To select the Automation mode for a track on Artist Control or Artist Mix:
1 Hold SHIFT while pressing the REC/AUTO key on a track.
2 Press SHIFT+REC/AUTO again to cycle to the next available automation mode such as Off, Read,
Latch, or Touch. Not all modes will be available; for additional modes, use the mouse and the onscreen track Automation mode selector.
I assume the "shift" is from the far bottom bottom on the center part of the Control.
Doesn't work. Tried with KB as well, to no avail.
On a VCA channel, nothing.
On an Audio channel it puts it into record
MAC 10.6.6, PT9.03, Eucon 2.6
Old 07-28-2011, 11:42 AM
jesse p jesse p is offline
Default Re: Can't change Automation modes with Control
I just checked this on win7
artist control
eucon 2.6
automation mode change it is functioning here with pt9.0.3 cptk
www.kdsound.net
Sound for film and Television
Old 07-28-2011, 11:44 AM
artist control
eucon 2.6
I'M on MAC. Just created a new session. Same thing. Shift (on the control) + Auto/REC = track in record ready.
Shift+fader does not set to zero either. Even though it is checked in the prefs.
AVID just told me they were going to deal with the automation modes in the next release. So is there any one on Mac that can confirm automation modes, or what seems to be, operations using shift and tracks, don't work in 2.6
Old 07-28-2011, 03:29 PM
JR Fountain JR Fountain is offline
Works on my MC Mix for what it's worth and I'm on a mac.
J.R. Fountain
credits: www.imdb.com/name/nm0288354/
system: Mac Studio Ultra, 128 GB RAM, macOS 13.6.1, MTRX Studio, S3 / Dock, PT Ultimate 2023.12
Old 08-01-2011, 02:11 AM
noeqplease noeqplease is offline
Location: Lake Arrowhead, CA, USA, Planet Earth, Solar System, Milky Way Galaxy
Mac OS : 10.6.7
Eucontrol : 2.5.7
Pro Tools HD : 9.0.3
MC Mix 1 Firmware : 1.4.4
MC Control Firmware : 1.2.6
MC Mix 2 firmware : 1.4.4
Automation modes toggle by using Shift button +"Auto" (Rec button) : WORKS on all three surfaces.
Fader Set to Zero : Using Shift + touching Fader, WORKS on all three surfaces.
Cheers
Nick Sevilla
[email protected]
Old 08-01-2011, 05:36 PM
Wish I knew what was going on with it.
Tried it on 3 different PT9 systems, same thing. I have noticed the shift key acts like it is stuck, even though the LCD doesnt show it as being active.
Very strange. after I hit the shift key and let it go, and go to select a region in PT, it acts as if I'm holding it down and selecting multiple tracks.
Old 08-01-2011, 10:57 PM
So I'm a complete idiot.
I've been using the Shift button in the center.
Today, or this evening, I look at the Control and said, "What's that unlabeled button".
The one at the bottom left of the unit.
Low and behold, that's the shift button. And the automation modes now change.
Why I never noticed that button before while sitting in front of me. I don't know.
I guess no one here noticed I wrote this:
"I assume the "shift" is from the far bottom on the center part of the Control."
Either way, It works. Thanks.
Old 08-02-2011, 12:00 AM
In this case, Ignorance, is truly not bliss...
The User Guide, page 27 :
Chapter4: SurfaceControls
Figure 4-1 MC Control surface
4.2 Shift Key
The Shift key is used in conjunction with other keys to access the functions la-
beled in blue above the primary function. Press and hold the Shift key, found at
the MC Control’s bottom-left and -right, then press the other key.
The User Guide uses the following simplified terminology to describe Shift func-
tions: “press the Shift + APPLICATION keys” is written as “press the WORKSTATION key.”
Nick Sevilla
[email protected]
Automation modes won't change on MC Control v2 on the touch panel and soft buttons filmsound_no Artist Series 6 11-24-2011 12:55 AM
How to program track automation modes noeqplease Artist Series 0 05-23-2011 03:44 PM
Windows7 64 Bit - Where is the Euphonix Icon to change modes Cyndicate Artist Series 1 03-16-2011 11:13 PM
change automation modes? Richard Fairbanks ProControl, Control|24, Command|8 2 07-11-2007 04:02 AM
bcf2000 & automation modes?HOW? maltezze 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-29-2006 06:59 PM
