Old 06-09-2009, 04:51 PM
tonejunkee tonejunkee is offline
Default Unable to import PCM files....
So I was given some PCM files of sound effects. I need to get these into PT8 and improve upon them. Why can't I import them? Isn't PCM a raw WAV file? Anyway, please tell me how to pull this off. I can convert them if needed.
it would be great to simply play these files! Are there any app suggestions??????
Old 06-10-2009, 02:36 AM
StavrosSound StavrosSound is offline
Default Re: Unable to import PCM files....
Try changing the extention to .wav and see what happens
No guarantees, but WAVs and PCMs are related (I belive its more or less a difference in the header/coding container, or rather lack of for PCM).
On that note, BWAV/BWF is the exact same thing as WAV, used interchangeably, the only difference from WAV being it has an extra RIFF data chunk for storing metadata such as timecodes, source, scene, etc
"White noise- the birth cry of the universe."
IMDb Credits
Old 06-10-2009, 12:28 PM
DigiTechSupt's Avatar
PCM files are usually raw, headerless audio, which is why you can't import them - without the header, Pro Tools doesn't know how to open them.
Hitsquad likely has an editor that can open a PCM file and export it as WAV...
Avid Audio Tech Support
Support FAQ
Unable to import some files because QuickTime is not installed? Mitchdeathshadow Windows 1 08-14-2013 09:29 AM
Unable To Import .rx2 Files ProTooler Pro Tools TDM Systems (Mac) 5 03-24-2013 04:43 AM
Unable to import REX or Acid files as group files in 7.4 Luigi Lazareno Pro Tools TDM Systems (Mac) 2 03-11-2009 08:07 PM
Unable to import .wav files Mike Borok 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 11-06-2007 01:16 PM
unable to import audio files coz quicktime missing Redsandblu Pro Tools TDM Systems (Mac) 2 06-21-2006 01:42 AM
