Old 01-25-2009, 05:41 AM
Patill Patill is offline
Default ProTools looses communication with interface, please help :(.
Hi!
I get the following error message:
Lost communication with the audio Interface. Please try increasing "H/W Buffer size" or removing some plug-ins and make sure you have a valid clock source. Press ok to reset Device (-6097)
What does that mean? I just started with a song using battery, no more Plugins yet. My H/W Buffersize was at 512, I set it to 1024, still the same problem. I have a very new Mac Pro with 6GB RAM, so whatīs the problem? I canīt hear any sound after that message.
Iīve never had this before when using ProTools 7.3, now Iīm using PoTools 8.
Old 01-25-2009, 05:53 AM
Default Re: ProTools looses communication with interface, please help :(.
oh my god, this is getting more bad .
Now I opened Xpand! and the Plugin window was yellow and had bad graphic problems (like only 256 colours???).
Them ProTools closed immediatly. What is wrong here? I think I need help very badly . My whole work is gone now...it wasnīt that much but you canīt expect that to happen every time, in fact it souldnīt.
look at this photo:
http://img265.imageshack.us/img265/5613/bild1tr1.jpg
Old 01-25-2009, 07:35 AM
ok, the problem with xpand has been solved. I thought it would be good to re-install ProTools (I had to install the Factory plugins for 7.3) and now it works (itīs Xpand2).
But the first problem stays and itīs even getting worse with 2 plugins opened (Battery and Xpand 2). It occurs, when i hit play and then stop. You hear the sound again and again getting more silent (like a Delay) and you hear a crackle out of the monitors.
I can solve this by going into "Setup->Playback Engine..." switching anything around. Then it works again three times maximum, then I have the same problem again.
Can you tell me whatīs wrong here?
Old 01-25-2009, 07:53 AM
Phil Ogden Phil Ogden is offline
It's probably Battery. NI have not quite got their act together re PT and Leopard support.
http://www.native-instruments.com/in...ard&L=1#c65525
Note. These kind of problems can persist even if the offending plug-in is not instantiated in a session. Try this,
1. Move the plug-in from Library/Application Support/Digidesign/Plug-ins to the adjacent unused plug-ins folder.
2. Delete Preferences
3. Clear Trash and reboot.
http://www.myspace.com/philogg
Old 01-25-2009, 08:13 AM
ah ok, so thereīs gonna be an update for Battery 3 soon?
I need Battery, no matter what! So I canīt remove it . I donīt have that folder anyway....
MC Control looses Logic Pro communication EdgarRothermich Artist Series 2 12-06-2012 10:52 PM
Lost Communication With Audio Interface classickstudios 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 02-14-2010 11:30 PM
003 - lost communication with audio interface -PT LE 8.1 alex s 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 33 12-01-2009 11:48 AM
003 rack looses communication on start up but pro tools opens normally Cirait 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 09-24-2009 03:58 AM
ProTools 8 looses instrument settings Mr.O Pro Tools TDM Systems (Mac) 1 05-25-2009 01:27 PM
