ProTools 6.4 causes reboot
After installing PT 6.4 on a new machine, I found myself not able to even load ProTools. As soon as I click on the PT icon, my computer instantly reboots itself. Also, Windows isn't even associating my PT session files with ProTools after installation. I recently had a Dell P4 and had no problems of this sorts. The update for PT 6.4 has been installed as well. Has anyone here had a similar problem or am I missing a step here? Thanks.
nmusic Setup: HP Pavillion D4000E ====== AMD Anthlon 64 3500+ 1 GB DDR PC3200 80 GB 7200 RPM SATA 16X DVD +/-R/RW Drive 16X Max DVD-ROM Firewire Card 128 MB DDR ATI RADEON X300 SE Sound Blaster Audigy 2 ZS Windows XP SP2 Digi002 Rack ProTools 6.4 |
Re: ProTools 6.4 causes reboot
You need to update your PACE drivers from www.paceap.com
I'm only using the plugins that came with ProTools 6.4 and do not require iLock. I didn't have to use iLock on my P4 Dell and everything worked fine. Unfortunately my P4 Dell died on me and now this new HP reboots itself every time I load up PT 6.4. |
You still need the PACE driver for Protools regardless of wether you have a iLok, It has to do with Protools antipiracy protection.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
As Sunburst mentioned, Pro Tools uses the PACE driver for it's authentication. "Reboot on startup" is a classic symptom of having an outdated PACE driver, and the problem/question has been experienced, posted about and solved enough times since 6.4 and Windows Service pack 2 came out that I am most confident that updating the PACE driver will solve your problem. (I'm actually kind of offended that you didn't believe me and instead of just trying it are arguing about it).
Just in case it doesn't solve your problem though, keep in mind that you need to also have the 6.4cs6 plugin update and the 6.4cs9 program update installed as well if you are using Windows XP SP2. P.S.; 6.4 is an extremely old version of the software at this point; I would highly recommend spending the cash and upgrading to the latest version.
Keep having to force reboot my pc after about 7-10 minutes of protools HD 10 | Reefachiefa | Windows | 2 | 12-03-2012 11:21 AM |
Protools Won't start without a reboot | funkmomo | Windows | 1 | 06-12-2012 03:24 AM |
Protools random reboot - please help | Superclock | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 07-18-2009 11:39 PM |
ProTools LE causing the system to reboot | FierceBrew | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 02-23-2008 08:38 AM |
ProTools makes my PC reboot!! PLEASE HELP | audiblepidemiks | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 08-09-2004 06:22 PM |
