Old 01-22-2019, 05:09 PM
Media Man Media Man is offline
Default i5 8400
I'm putting a computer system for a friend to run Pro Tools on. He is a world class musician, but a new PT user, so I will give him a few lessons to get him going.
My question is if the i5 8400 processor will have enough steam. He is on a budget, and a move up to the i7 will cost a couple of hundred bucks more.
I have a dual Xeon set-up, so don't have any hiccups.
So will the i5 be powerful enough for native?
Media Man
Old 01-22-2019, 07:08 PM
Southsidemusic's Avatar
Default Re: i5 8400
A stable solid system should be an i7 CPU and the minimum for PT is 16GB Ram and a SSD internal drive for OS and atleast a spinner 7200rpm or better for recording to.
I would not invest in an i5 CPU as it might croak sooner or later and saving money on the wrong pieces is not a good idea
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 01-23-2019, 02:11 AM
Default Re: i5 8400
"Go faster" is always good advice, but I'm wondering about real world experience with i5 processor running Native PT out there.
I have always been an HD guy, converted to Native HD when HDX became cost prohibitive for my business, so looking for advice from those running straight native PT 12.
FWIW, Avid recommends i5 as minimum requirements for PT 12 on the website, and SSD is not part of that minimum requirement that I can see, even though it makes perfectly good sense.
Media Man
Old 01-23-2019, 02:37 PM
Default Re: i5 8400
Maybe a better question is; what does your friend need to do? If they're going to be playing around with small sessions and only a few VI tracks, then maybe an i5 is enough(summing an i5 quad-core). But if they plan on doing full-blown productions with lots of plugin orchestration...they should be prepared for disappointment(at the least) or out-growing the system in a short time. It can cost more to upgrade later vs buying right in the first place.
Look at it like this: You spend $1K on a "budget" build and you outgrow it in 2 years, it cost you $500 per year. Spend $1500 on a "power" build and it lasts 4-5 years before you outgrow it. Your per-year cost is much lower
Having said all that, what is the budget? Maybe instead of building a new system, the money could buy a used computer with more horsepower? I recently purchased a refurb HP Z820 workstation for $1100. Specs were dual XEON 6-cores @3.5GHz, 64GB of RAM and a 500GB SSD for Windows. That's a lot of bang for the buck(and way less than my last X79/i7 build)
BTW, I would expect a world-class musician to outgrow a budget rig in very short order.....
Old 01-23-2019, 04:12 PM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
Default Re: i5 8400
I'm on Windoze , i have one lappie with an i5, one with an i7 duo and desktop with i7 fourcore all running 2018.12 "Native" or whatever they are calling it(Not ultimate,maybe, i dont know). The i5 is used only for small stuff as it will choke when track numbers and cpu hog plugins are in use. It's perfectly fine for singer sonqwriter stuff, with a FEW VI's OR no VI's and higher track counts. My old G4 850 with PT 5.3 is just as good so that kinda tells you there are some limitations. But not entirely unworkable. More VI's i would def go for the fastest i7 he can afford. IMHO
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro
PT 2023.3 Studio through an A&H Qu-32
Old 01-23-2019, 07:58 PM
leftalive leftalive is offline
Default Re: i5 8400
What kind of computer does he have now? Or does he not have one at all? (I know some people just rely on phones and/or tablets for daily stuff...)
I ask because an i5 rig wouldn't be a whole lot more powerful than what most folks are using as a daily driver these days, in which case, maybe he should just grab a copy of PT first and get his feet wet that way. (Again - depends on what he's using now)
That said, If your friend is new to Pro Tools, then handing him a machine that is underpowered might be last thing you want to do. He's going to have his work cut out for him as is, just learning to navigate the software.
It could be years before he's able to tell the difference between 'this problem I'm having is due to limitations with my CPU' and 'this problem I'm having is due to [literally anything else]'.
If you want to save cash on a build, there are other places that make more sense. I really wouldn't recommend going below an i7 anymore.
PC workstation:
Windows 10 Pro
i7 12700K
RTX 2080ti
64GB DDR5 5200mhz RAM
2 Samsung 980 Pro 1TB SSDs
Samsung 850 Pro 1TB SSD
LG 34" Ultra-Widescreen monitor
Pro Tools 12.4
A loaf of bread
A stick of butter
A lot of rye whiskey
Old 02-07-2019, 04:48 AM
Prabha Prabha is offline
Default Re: i5 8400
Faster is better, yes....
BUT I do run a i5 6600 in my comercial studio everyday and very, very rarely the cpu puts a limit on my work (use lots of plugins, even reverbs and delays when tracking).
The hardware buffer is almost always at 64 even on large mixing (50+tracks) sessions. And always at 64 when recording (I do a lot of jazz and big band sessions creating several headphone mixes in PT)
PC i79700K 4.8Ghz 32Gb ram Nvidia1050
Win 10 64
SSL MX4
Dell Dimension 8400 and 002 Chence 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 03-18-2009 03:51 PM
New Mbox and Dell 8400 and Intel boombatz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-09-2006 01:22 PM
Dell 8400 Memor Errors in PTLE 6.new chris digi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 08-25-2005 02:13 PM
DELL 8400 ... INTEL 925 CHIPSET PROBLEM CHEEZGRITS 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 12-30-2004 09:31 PM
MBox NOT compatible with Dell 8400!!!!!!! guest4254 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 21 12-03-2004 07:31 PM
