Spot doesn't work...
Hi
Has any one had any problems with the Spot function. It seams to have disabled, If i right click a region and select spot nothing happens (It used to open the spot window). The same happens when i select spot in the top left hand corner of the edit window, I can select the function, but then when i select a region nothing happens. Thanks, Dave PT 7.4.6 Mac 0S 10.4.9 HD 3, D-Control, X-Mon, 192's, Mojo |
Re: Spot doesn't work...
You have Auto Spot regions turned on.
Thanks,
Do you know how to turn it off? |
Under the Options Menu
Try typing "CMD-P", as if you were going to print. That toggles this function. A booby-trap, if you ask me.
and I'l say it again:
Spot/Auto Spot should toggle the way Grid and Grid Relative toggles (or at least is status)
Spot function will not Spot?? | frequencypoet | Pro Tools TDM Systems (Mac) | 4 | 02-08-2010 11:29 AM |
Spot funktion don't work anymore | test tube | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 09-08-2008 10:19 AM |
Since yesterday spot function doesn´t work anymore | abx992000 | Pro Tools TDM Systems (Win) | 2 | 05-10-2008 07:34 AM |
spot mode sometimes doesn't work | Bryan Cook | Post - Surround - Video | 7 | 12-20-2003 09:04 AM |
SPOT function does not work !!!!! | Michael Klinger | Pro Tools TDM Systems (Mac) | 1 | 09-27-2001 12:57 AM |
