Where could I get this "blanket"??
What's up,
I ran across this and I wanted to know where I could get this. I think its a good idea. http://i19.photobucket.com/albums/b1...o/DSCN5258.jpg
MBox 2 Mini Pro Tools 7.4 - MPTK Sony VAIO VGN-NR120E Windows Vista Home Premium |
Re: Where could I get this "blanket"??
that actually wont do a whole lot. there just isnt enough mass. you would be better off looking into some owens corning 703, or john manville 814. MUCH more effective at absorption.
Both these setups seem like they could work, as far as reducing the amount of sound that is reflected to the room and then coming back into the mic. So as a portable "DRY" enviorment I'd say yes. (the metal mesh on the first pic seems like its meant to diffuse...)
They will likely be worthless in stoping external noise sources from being recorded since (as mentioned) they have little mass. This is not an alternative to an ISO booth.
i7 2600K @ 4.4GHZ -- Intel DP67BG B3 -- 8GB DDR3 1600 -- Crucial SSD PTLE 8.0.4cs2 -- DIGI 003R -- DV toolkit -- Waves 9 |
Well I definitely can't afford an ISO booth haha I'm looking for a cheaper way that works with vocals.
Not sayin you should build one.
Is your problem noise from the outside coming in? or room reflections? For the latter these type of solutions work. However if your problem is, say, traffic noise coming in, this might dampen it a bit but will not block it. Blocking sound requires mass and/or dead air space (trapped between 2 sealed walls or windows). Still, in the mix the signal of the vocal is typically so much loader than any noise recorded with it so Ghetto recordings work :)
ahhh ... the old U-Haul packing blanket trick. It WILL indeed work for making a "dead" area so your vocals will be drier sounding. Won't stop much of any other room noise coming through though. I used to do this before I could afford to build an iso booth, and it worked well for taming the reflective sounds .
The Freakin' Harborcreekin' www.norwegianwoodstudio.com Sweetwater Creation Station 400 i7, 3.4 ghz, W7 Home Premium, PT 11.3, Focusrite Saffire Pro 40 & Pro 14, Focusrite Octopre Mark II, A&H GL2400/24, Event 20/20 V2's, 2-24" Video monitors, a whole buncha hard drives, 3 lava lamps AND an official "unsuck" button!! |
Experimenting with microphone placement and pattern can do a lot for you, depending on your room sometimes aiming the center of a cardioid pattern toward a corner of a room will help turn poor reflections into better ones. Or aim the rejected portion of the pattern toward any unwanted sound source. Play around, this stuff can make a difference.
Have you tried facing your vocalist into an open closet full of coats?
q6600-ASUS P5K SE(P35),2GB Crucial BallistexDDR2 800,ASUS EN7200GS 256MB,80GbMaxtor-80GBWestern Digital,Samsung SATA DVD burner,Mbox2 PTLE 7.4cs7 |
The audiomute blankets are great. You'll be surprised how well they keep reflections down.
Win7 64 Ultimate - Intel Core i7-920 Bloomfield 2.66GHz - Gigabyte EX58-UD3R - OCZ Gold 6GB - Radeon X550 256MB Video Card - 750GB Caviar Black System, 500GB Hitachi SATA Sample, and 750GB Caviar Black Audio - 500GB Caviar Blue Backup - Pro Tools 8.0.4 LE - Signature Series Digi 002R |
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? | bashville | Pro Tools 10 | 5 | 03-23-2013 03:04 PM |
"Blanket of white noise" | Stay Where I Can | macOS | 3 | 11-26-2011 08:41 PM |
Pro tools 9 crashes at startup "Bus error" in thread "MainThread", at address 0x0 | danball | macOS | 2 | 09-26-2011 04:49 PM |
hardware buttons for "preview", "capture" and "punch" | evs | Post - Surround - Video | 1 | 12-06-2010 12:28 PM |
The "FATE" of CM LABS "MotorMix" & "MotorMate". Dum dum dum dum... | leon777 | Pro Tools TDM Systems (Mac) | 21 | 10-15-2002 12:00 AM |
