Old 08-21-2001, 09:47 PM
Slaterman Slaterman is offline
Default MacOS 9.2.1
MacFixIt is keeping a forum on the newest version of MacOS 9. I'm wondering if upgrading the OS will affect operation of PTLE or not. Here's the link to the MaxFitIt forum:
http://www.macfixitforums.com/php/po...at=&Board=OS92
Ted.
Old 08-22-2001, 05:45 AM
dannepop dannepop is offline
Default Re: MacOS 9.2.1
Yes, has anyone upgraded and made a test with Pro Tools yet?
It would be interesting to know!
danne
Old 08-22-2001, 11:28 AM
lexicon5 lexicon5 is offline
The 9.2.1 upgrade is directed more toward OS X compatibility issues. I have upgraded my main HD to 9.2.1 and will at least try it on my Pro Tools drive tonight.
Here are some links to Forums discussing the upgrade. Although aimed at OS X, there are numerous updates to OS 9 apps. The second link has a post with a list of all affected areas.
http://www.dslreports.com/forum/rema...cdsl;mode=flat
and http://www.dslreports.com/forum/rema...cdsl;mode=flat
It's such a fine line between stupid, and clever. -David St. Hubbins
Old 08-22-2001, 01:04 PM
Slim Shady Slim Shady is offline
Just installed 9.2.1 on my backup machine (G4/450/256) - Pro Tools LE 5.1.1 runs fine, I haven't had a chance to do much more than open a session and make sure it plays, but at least it will do that much for sure. I'll post more if I get a chance to do more tests, or perhaps I'll get the gonads to install it on my main system as well. Either way, I'll let y'all know if anything unusual turns up.
Cheers,
Old 08-22-2001, 03:32 PM
The install turns AppleTalk back on but leaves the memory settings as they are.
Old 08-22-2001, 05:10 PM
Christoph1123 Christoph1123 is offline
I've got 9.2 on my new G4 867, so far so good. Have yet to really flex it, I'll keep you posted.
Genuinely, Chris
Genuinely, Chris
Old 08-26-2001, 06:53 PM
phillip@princeton.edu phillip@princeton.edu is offline
[QUOTE]Originally posted by Ludwig_Van:
[QB]I just moved my 001 system to my new G4 dual800. I believe the PCI card is picking up computer noise and braodcasting it thourgh my 001. When I scroll windows or double click a drive, you can hear the actions coming through my external speakers.
This is a pre-existing problem. Go to the modem control panel and turn off the sound there. This should fix the problem.
Old 08-26-2001, 08:36 PM
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR>Originally posted by Ludwig_Van:
Also, when I have Pro Tools open (5.1.1) and check the system usage, the PCI meter is always in the red. Sometimes my playback audio is stopped and I have to click stop on the transport and then play again to get the audio back....<HR></BLOCKQUOTE>
I've noticed (now that I've got 9.2 on my PTLE computer) that both CPU usage and PCI usage are higher on the scale. Hm. Projects that used to run fine now stop because of too much CPU usage. Hm.
Old 08-26-2001, 08:53 PM
KamaSutra77 KamaSutra77 is offline
I did a little test of my configuration.
G4/450 (2nd rev computer)
Audio played back from a second internal ATA 100 IBM dekstar 60 Gb drive.
Buffers are set generously.
Ram is set genourously.
My results:
24 audio tracks.
20 instances of various RTAS plugins (the only factor that seemed to affect CPU performance).
24 Aux Audio channels
No hiccups. A little slower response at play begin and end (actually a lot slower response, typical of ATA drives though).
Note: only 6 tracks had audio, not sure if that negates my results or not. Suffice to say there where very few edits i.e. fades/regions within those tracks.
PTLE 5.1.1
If I get aroudn to it I'll try to do another test with full /edited audio tracks, and some midi thrown in.
[ August 26, 2001: Message edited by: KamaSutra77 ]
Huh?
Old 08-26-2001, 09:53 PM
phamtec phamtec is offline
Just anecdotal...
I installed 9.2.1 and 5.1.1 on my machine on the weekend and then did some heavy editing of an audio session without incident.
I also tried PT in Classic Mode on my OS X (I have 10.1) with 2.6.1 just to see if it would work, but it still comes up with "Couldn't make DAE Deck". So no joy on that yet.
So I think it's worth getting the latest. If you use OS X then it will help a lot for the classic stuff.
6.0 and Macos X gmcgmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-11-2003 09:08 AM
Macos X gmcgmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 11-12-2002 09:25 AM
MacOS X is getting old... Samuelsson Pro Tools TDM Systems (Mac) 0 03-07-2002 11:09 AM
MacOS X ilnegro 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 12-26-2000 10:03 PM
PT TDM 4.3.1 on G4-AGP w/MacOS 9.0.4? Dzerdzinsky Pro Tools TDM Systems (Mac) 3 06-22-2000 12:40 AM
