Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools HDX & HD Native Systems (Win)
Old 12-23-2013, 03:17 AM
kyteman kyteman is offline
Default Re: 2x Xeon 2697 v2 build
On the subject of fans, you were right. for one, I did indeed underestimate the bulkiness of the coolers. more importantly, supermicro uses narrow ILM while the standard is square ilm. noctua doesnt support narrow, so won't be able to use them. I'm checking now if the SNK-P0050AP4 by supermicro will do the trick.
EDIT
Found a solution, its a pair of NH-U12DX i4. will test those, see if its good.
Old 12-23-2013, 09:45 AM
Emcha_audio's Avatar
EDIT
Hopefully they will work. They seem pretty big but I think they will fit from what I can see. Just need to check the spacing before buying to be on the safe side.
Manny.
Wave-T.com
Old 12-25-2013, 10:49 PM
RyanC RyanC is offline
On the hack bandwagon it's worth noting that so far there are no confirmed reports of anyone having turbo states working for LGA2011 processors. Fixed overclocks are fine with OSX but turbo states require the OS to up the multiplier when needed.
It's been hypothesized that the release of the nMP should provide a system definition that supports this, but I've been following it on tonymac and so far nothing under 10.9.1 (could change).
There is a single geekbench test that would suggest that somebody has it working (50k+), but I would expect that to take a lot of deep hacking of OSX (beyond the tonymac guys) to obtain. Maybe he has unlocked engineering samples (supposedly they do exist)....
Probably safer to run this as a win machine, especially for pro work, who knows how much hacking the kernel benefits us audio guys?
Old 01-30-2015, 03:54 AM
dtonthept dtonthept is offline
Hey did you ever build this? Let us know how it went (or didn't!)
D
Old 01-30-2015, 07:15 AM
Brandonx1 Brandonx1 is offline
I would just think about this asus motherboard. asus z9pe ws
Brandon Howlett
Vibe Audio Post, Inc.
Re-recording Mixer
Custom Build CPU, HDX 1, Omni, 192 I/O Digital
S6 M10 24 fader
Satellite Mac Pro, HDNative, 192 I/0
Black Magic HD Extreme
New Build Review! Based on Mano/Ame? and SPCR Fanless build Calipoop Windows 4 11-16-2011 09:38 PM
Allen, Would you build a dual xeon? Glenrose_Media 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-22-2005 03:51 PM
To build or not to build? Money is the question... storm-01 Tips & Tricks 5 09-23-2003 01:08 PM
To build or not to build? Money is the question... storm-01 Pro Tools TDM Systems (Mac) 12 09-19-2003 07:40 PM
To build or not to build? Money is the question... storm-01 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 09-18-2003 09:13 PM
