Old 03-28-2017, 10:43 PM
Sparky1 Sparky1 is online now
Default Solo 1 Track When Many Solo Tracks Exist...
Hi there.
Sometimes when I am mixing I will solo a few tracks together to see how they sound. Then in the course of doing that - I occasionally want to hear just one of the solo'd tracks.
Is there a key command to just hear 1 solo track out of the group of solo'd tracks?
Thanks,
Sparky
Old 03-29-2017, 01:19 AM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
Default Re: Solo 1 Track When Many Solo Tracks Exist...
command+click the track that you want to solo (which de-selects it), then press shift+m (muting the rest of the soloed tracks). This method allows toggling between your selected track and the rest of your original group.
-or-
select the track that you want to solo (this would de-select the rest of your group), then quickly press shift+s twice (this would un-solo your selected track and then quickly solo just your selected track). This method does not allow toggling between your selected track and the rest of your original group.
-Ryan Young
•2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Additional Systems
•2010 Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 (OS 10.14.6) •HD Native PCIe, 192 I/o, 96 I/o, Pro Tools Ultimate •McMix (x4), McControl (x1), JLCooper Surround panner for D-Command ES, Avid Control •Blackmagic Intensity Pro (HDMI) •7.1.4 Room with JBL LSR4300 series
•2017 MacBook Pro 2.8 GHz i7 - 16 GB 2133 MHz LPDDR3 (OS 10.14.6) •HD Native TB, HD Omni, Pro Tools Ultimate •McMix (x1), McControl (x1), Avid Control * or * D-Command ES Main Unit •Fed into whichever system is the main system
Old 03-29-2017, 06:52 AM
john1192 john1192 is offline
since there is No Direct key command .. the simplest might be ..
1) over the track that you wish to be solo'd in the end - Hold Option and Click to release all Solo's
2) since you are directly over the track you want to Solo now release Option key and just click solo on track ..
that said:::
there are a few Modifiers available, shift, control, etc, that could be used without affecting another feature .. i would vote for Option/Control/Click as Control is the modifier that solo's a track when it is part of a group and option being all of the solo'd tracks, makes sense that the combo would create One Macro of sorts - "undo all solos and solo selected track" .. a pretty natural muscle memory thing ..
you should post this on Ideascale ...
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 03-29-2017, 09:06 AM
midnightrambler midnightrambler is online now
No offence, but I could think of a billion things that I'd rather AVID worked on than this. And, not that I want to start a flame war or anything, but I'd argue if a user needs to "solo" a "solo", i.e. when they're already using "solo", then they've totally misunderstood how "solo" should be used...(the clue is in the name)
Old 03-29-2017, 10:29 AM
JFreak JFreak is online now
One could also mute the tracks not wanted to be soloed and then solo the track that has more interest...
Old 03-29-2017, 11:12 AM
The Weed's Avatar
The Weed The Weed is offline
Set your Option for Solo to X-OR. This way only one track will Solo at a time. To have more than one track Soloed, Shift+Click on any other track or tracks' Solo Button(s).
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 03-29-2017, 02:20 PM
Toggling would be nice .. between 2 Solo States .. so you would not lose your solo by accident ..
and no offense taken .. i would so much like to see the bugs worked out asap .. before anything moves forward ...
cheers john
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 03-29-2017, 02:43 PM
+1
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~
~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG
~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~
Send mute/solo follows track mute/solo pre-fader Roger_Jam_Jet Windows 3 09-24-2017 01:59 PM
Can't Solo Tracks When Bussed To Aux Sends / Solo Safe is armed (Greyed Out) adrianrobison macOS 5 11-19-2014 05:09 PM
Problem:Selecting Solo on 1 Track Selects ALL Tracks Aten Pro Tools TDM Systems (Win) 7 10-31-2014 04:46 AM
Protools 10: mute and solo aren't working. (Solo safe is not on any of the tracks.) charlottewrinch macOS 2 04-14-2012 05:32 PM
Solo single voc track, hearing other vocals tracks too help? Seti Orion Pro Tools TDM Systems (Mac) 4 03-07-2008 06:11 PM
