Distorted playback
Hi everyone. Thanks for advice in advance. I Installed PT 9 today with the updates and driver updates. I have a 002 rack and playing sessions results in a very digitized distorted playback that seems to be slowing down and speeding up.
Here are my pc specs Windows 7 home premium 64 bit Intel i7 [email protected] 8 gig of ram two samsung HD103SJ ATA drives |
Re: Distorted playback
I've just tried running a session with my mbox 2 and all seems fine. could a dodgy firewire cable or connection be the problem?
BUMP
Even playing a track on media player via the outputs of my 002 resulted in the same problem. As this happened i double checked my 002 on an older PC of mine and it worked fine. Also tried the legacy firewire driver and PT9 wont even play a track using that driver. getting really stuck now. heres my sandra report SiSoftware Sandra Computer Model : Asus V-P7H55E Workgroup : WORKGROUP Host Name : user-PC User : user Processor Model : Intel(R) Core(TM) i7 CPU 870 @ 2.93GHz Speed : 3GHz Cores per Processor : 4 Unit(s) Threads per Core : 2 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 On-board Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 On-board Cache : 8MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 16 threads sharing Computer Mainboard : Asus V-P7H55E BIOS : AMI 0504 07/16/2010 Bus(es) : ISA X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 8GB DIMM DDR3 Chipset Model : ASUS Core (Clarksfield/Lynnfield) DMI Front Side Bus Speed : 2x 2.4GHz (4.79GHz) Chipset Model : Intel Core Desktop (Lynnfield) UnCore Front Side Bus Speed : 2x 2.4GHz (4.79GHz) Total Memory : 8GB DIMM DDR3 Channels : 2 Memory Bus Speed : 2x 665MHz (1.33GHz) Memory Module(s) Memory Module : Corsair CM3X2G1600C9B6 2GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5) Memory Module : Corsair CM3X2G1600C9B6 2GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5) Memory Module : Corsair CM3X2G1600C9B6 2GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5) Memory Module : Corsair CM3X2G1600C9B6 2GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5) Video System Video Adapter : NVIDIA GeForce 210 (16 SM4.1 1.4GHz, 512MB DDR2 128-bit, PCIe 2.00 x16) Graphics Processor OpenCL Processor : NVIDIA GeForce 210 (16SP 2C 1.4GHz, 512MB DDR2 128-bit) Compute Shader Processor : NVIDIA GeForce 210 (16SP 1.4GHz, 512MB DDR2 128-bit) CUDA Processor : NVIDIA GeForce 210 (16SP 2C 1.4GHz, 512MB DDR2 128-bit) Storage Devices SAMSUNG HD103SJ (1TB, SATA300, 3.5", 7200rpm, 32MB Cache) : 932GB (C:) SAMSUNG HD103SJ (1TB, SATA300, 3.5", 7200rpm, 32MB Cache) : 932GB (E:) Optiarc DVD RW AD-7260S (SATA150, DVD+-RW, CD-RW, 2MB Cache) : 64MB (D:) Logical Storage Devices System Reserved : 100MB (NTFS) New Volume (E:) : 931GB (NTFS) @ SAMSUNG HD103SJ (1TB, SATA300, 3.5", 7200rpm, 32MB Cache) Hard Disk (C:) : 931GB (NTFS) @ SAMSUNG HD103SJ (1TB, SATA300, 3.5", 7200rpm, 32MB Cache) Audio CD (D:) : 0bytes (CDFS) @ Optiarc DVD RW AD-7260S (SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : ASUS H55 LPC Interface Controller LPC Legacy Controller 1 : T0 B0-73 Audio Device : ASUS P55/PM55/3400 High Definition Audio Audio Codec : Realtek Semi High Definition Audio Audio Device : CardExpert Tech High Definition Audio Controller Audio Codec : nVidia 000Bh Audio Codec : nVidia 000Bh Audio Codec : nVidia 000Bh Disk Controller : ASUS P55/PM55/3400 4 port SATA IDE Controller Disk Controller : ASUS P55/PM55/3400 2 port SATA IDE Controller USB Controller 1 : ASUS P55/PM55/3400 USB2 Enhanced Host Controller USB Controller 2 : ASUS P55/PM55/3400 USB2 Enhanced Host Controller FireWire/1394 Controller 1 : ASUS IEEE 1394 Host Controller SMBus/i2c Controller 1 : Intel ICH SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : Realtek PCIe GBE Family Controller Wireless Adapter 1 : Belkin Surf & Share Wireless USB Adapter (802.11g (ERP), TKIP, 54Mbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows 7 Home 6.01.7601 (Service Pack 1) Platform Compliance : x64 Windows Experience Index Current System : 4.7 |
Now I've used the mbox for say 10 minutes on a session the slowing down/digitized distorion is happening. The only difference being that the when I use the 002 it happens straight away. I'm guessing its not a firewire problem then
*Bump*
Number 1 issue that jumps out at me is your wireless USB. Remove it and uninstall its drivers and try again then. It may seem drastic but the drivers will have to go just to be sure - make sure you re boot after you have un installed those drivers :) Report back and we will move onto the next thing ( But I bet you it fixes it ) |
Hi Russell thanks for the advice. It didnt work unfortunately. Any other ideas?
Ok, Here are a few more :)
1) What is 'card expert HD audio driver' and remove it and re boot try with Mbox. By the way , is this Mbox 2 or above ? Mbox 1 is no longer supported. 2) What sample rate are trying to use ? Increase to 1024 samples and see if this goes 'away'. Alright , let me know how you go. If this does not help , be prepared for a 'geek alert'. We might have to dig a little deeper :) |
Distorted Playback for all sound | Seangleeson1 | Windows | 0 | 07-05-2012 07:25 AM |
Distorted Playback | carnology | Windows | 1 | 07-04-2012 08:42 AM |
distorted playback | soeasy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 04-18-2005 01:48 PM |
Distorted Regions On Playback | gazblake | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 07-26-2004 05:49 AM |
Distorted playback | Sherry Q | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 04-11-2003 12:21 AM |
