Old 07-10-2015, 04:56 AM
Serikiito Serikiito is offline
Default Can't import audio into Pro Tools 11
I'm currently using Pro Tools 11.3.1 and I can only import audio once. If I try again it doesn't bring up the audio import window after I click done.
To fix this I have to restart Pro Tools but this means I can only import once in a session before I have to restart Pro Tools.
I'm using a Macbook Pro 15" Mid 2014. Yosemite 10.10.2
Old 07-10-2015, 04:58 AM
Drew Mazurek's Avatar
Default Re: Can't import audio into Pro Tools 11
Have you done all this?
http://duc.avid.com/showthread.php?t=54888
www.drewmazurek.com
Old 05-21-2018, 11:48 PM
FunkFlorida FunkFlorida is offline
I have the same problem on Pro Tools 12.0.0
(Yosemite 10.10.2, iMac Late 2013)
Any help would be appreciated
Old 05-22-2018, 04:36 AM
Default Re: Can't import audio into Pro Tools 12
You might want to update PT.
Also this would have gotten better traction if you'd have posted a new thread over in the PT12 subforum instead of camping on a thread for a different version of PT then you have.
Jack
QAPLA!
Old 05-22-2018, 01:21 PM
Thank you sir! $299 for fixing an Import Audio glitch sounds expensive to me
Old 05-22-2018, 01:51 PM
You don't have an update past PT12.0.0 in your Avid user account? That's what I'm talking about. I don't think you're going to find too many people here on the initial release.
Where are you trying to import from - an external drive and if so is that drive formatted to work on a Mac? I imagine you're trying to use the import audio command. Try dragging and dropping the file into a PT session and see if that works.
Jack
QAPLA!
Can't import audio file on Pro tools 11.3 longname Pro Tools 11 1 12-23-2014 02:56 PM
Import Audio Not Responding Pro Tools LE 8.0.5 bpannell3 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-30-2012 04:20 PM
Unable to import mp3 audio in Pro Tools LE 8.0.4 d_sellers 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 10-10-2010 04:53 PM
Bwav Audio Import To Pro Tools jervin Pro Tools TDM Systems (Win) 2 04-30-2008 05:37 AM
import audio pro tools 6.0.1 mersisblue 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-12-2003 07:58 PM
