#21
Re: Pro tools 2022.6 released
Yes that's how Ableton (11.1+) works with AU plugins on Silicon. It should be noted, though, that this works due to a compatibility layer from Apple, specific to the Audio Units format. You can have a mix of intel and silicon AU plugins, and Ableton will use whatever's best/available. The downside is that you then end up with a bunch of instances of Rosetta—one for each intel plugin—and it can end up being more cpu-intensive than just running the whole DAW in Rosetta mode. VST & VST3 plugins do not have this capability, so silicon-native Ableton can only run silicon-native VST/VST3 plugins.
* Macbook Air : M1 ~ 16gb ~ 1tb ~ Ventura latest * Hackintosh : i9-9900k ~ 16gb ~ 3tb ~ Monterey 12.6.1 * PT 23.6 + Ableton Suite 11.3 * Soundtoys + Valhalla + Fabfilter + Spitfire * RME Fireface UCX II ~ Arturia Keylab Essential 49 * various clarinets, trumpets, flutes, plucky stringy thingies |
#22
https://www.mediafire.com/view/xxnp1...24.17.png/file
And it seems they've broke a custom shortcuts for the MacOS. The ones we make trough a System Preferences Keyboard tab. No way I can call a AudioSuite Gain plugin at a press of a button for example... And no internal Pro Tools option to do that.
Pro Tools Ultimate 2022.10 Mac Studio M1 Max 32GB RAM 2TB SSD MacOS Monterey 12.6.1 RME DigiFace USB Apogee Rosetta 200 Last edited by djani; 07-02-2022 at 02:28 AM. Reason: Expanded the explanation |
#23
Re: Pro tools 2022.6 released--selection of midi notes disabled after quantize
MP5,1 12core 3.46ghz 96GB Ultimate HDX https://www.youtube.com/channel/UCIA...Rnu0Jfh-YsgftQ |
#24
#25
Oh no, I still use that for gain plugin. But I can change it to soundflow… I’ll try that before upgrading. Sent from my iPhone using Tapatalk
http://www.ricardomosca.com Hackintosh, 3,7 GHz 10-Core Intel i9, 64 GB 3200 MHz DDR4, OSX Catalina 10.15.7, PT HDX 2023.9.0, SSL 4040G+, tons of outboard Mac Book M1 Pro, 16GB RAM, OSX 23.6, PT Studio 2023.9.0 |
#26
2. Make new Window Configuration of default view. Set it to config (1). 3. Open a Gain Audiosuite plugin. (and a normalize, and a meter, etc..) 4. Make new Window Config of this view. Set it to config (2), etc... 5. Save a new Session Template. Now, when you create a new session, use your template and ALWAYS access config (2) via ". 2 *" on a numpad. This is the preferred built in way recall window configs in later/new sessions (an open Gain plug-in, etc...) However, I can relate to you wanting your existing method to just work the same way. I never used System Pref's keyboard shortcuts. What happens when you do the old shortcut? If a new default MacOS action is triggered, maybe you can change the default to another key combo, and PT will listen to the old command again.
___ >> me: nednednerB // ||main gig: editing audio voiceovers & testing software | 2nd gig: music software tutoring | hobby: electronic music // ||software: Sonoma 14.2 | PT Studio 2023.12 | Ableton Live 11 | iZotope RX, Ozone, Neutron | Arturia Pigments | Auto-Tune | Dubler2 // ||system: iMac (Retina 5K, 27", 2020) 10-Core-i9 | 128GB-DDR4 | 5700-XT-16GB | OWC Thunderbolt Hub and Thunderbolt 3 Dock // ||devices: RME Babyface Pro FS | Focusrite Clarett 2Pre | some AT mics | SM58 | Ableton Push 2 | Sennheiser HD 600 HP // Onkyo TX-8220 SR ||automation: SoundFlow | Stream Deck+ | Keyboard Maestro | SteerMouse | MacOS Shortcuts // |
#27
Mac Mini M1 16 GB OS 12.7.4 PT 2024.3.1 |
#28
Pro Tools Ultimate 2022.10 Mac Studio M1 Max 32GB RAM 2TB SSD MacOS Monterey 12.6.1 RME DigiFace USB Apogee Rosetta 200 |
#29
Updated from 2021.10 and it was the smoothest Pro Tools update I've had in recent memory. No hangs, corrupted prefs, or other issues that have plagued previous updates.
Loving the new Atmos Bounce options - that alone will save me a ton of time. And, I can finally kill the N key right within Pro Tools without using SoundFlow Just wanted to share a positive experience on here for a change. :)
2019 Mac Pro 7,1 192 GB RAM Catalina OS 10.15.7 PT Ultimate, or whatever 2022.6 is called now HDX 2 w MTRX, Dadman 9.1.4 Dolby Atmos over Dante to external RMU |
#30
MP3 Conversion Quality with Pro Tools 2022 x Pro Tools HD10.3.10 | Alécio Costa | Pro Tools | 4 | 06-01-2022 11:58 AM |
Crash moving tracks to new Routing Folder in PT 2022.4 [FIXED 2022.5] | Dizzi45Z | Pro Tools | 43 | 05-29-2022 03:59 AM |
EUCON 2022.4 Released | EddieJones | Avid S1, S3, Dock and Control App | 17 | 05-08-2022 07:26 PM |
EUCON 2022.4 Released | EddieJones | Avid S4/S6 | 0 | 04-29-2022 03:32 PM |
Ozone 9 Advanced Version 9.12 released April 8, 2022 | gives | AAX Plug-ins | 0 | 04-10-2022 02:27 PM |
