Best Hookup
I have an 003 console and have some new gear I would like to hook up.
I have two Avalon 737B preamp/com/eq. Two Universal audioTwin Finities going into two DBX 160x compressors. Daking Mic Pre IV going into DBX 166 compressors I already have a Motu 828 bringing in 8 additional channels for drums which I do not use very much as I work on Acoustic stuff almost all the time Should I run the higher end stuff using the line in 5-8 and the daking 1-5 I was told that if I use the 1-4 preamp channels That even if they are turned all the way down you are not truly bypassing them. I guess I am asking if you have a preamp that is much better than the 003's how should I bring them in. Are there other options? Thanks |
Re: Best Hookup
Your options are inputs 5-8 or convert to ADAT or SPDIF for extra IO
MacBook Pro (silver) 2.5 GHz Intel Core 2 Duo - 4 GB RAM - 10.6.6 - PT9 - 003 BLA sig mod Terrarium HD3 Accel on a PowerPC - OS 10.5.7 - PTHD 8.0cs2 (3)192/SYNC IO/CS HEDD192/Studer A27/Neve 48 Ch. VR console |
Re: Best Hookup
Is there a way I can use better converters?
If so would I have to unhook my Motu using the optical connection or can I use the spdif |
Re: Best Hookup
ttt
Re: Best Hookup
4 ch with Digi 003 pres, digi converters 4 ch line inputs, digi converters 8 ch via ADAT, your converters 2 ch via spdif, your converters 18 inputs total..
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
Re: Best Hookup
Thanks Flommer
You answered my question well Now I am wondering two things If I have a preamp plugged into 1-4, If I have the preamp knob on the 003 turned all the way down am I bypassing the preamp and using the higher quality outboard preamp. If I want to use the higher quality outboard preamps is there a way using apogee converters |
I need a 11R hookup tip | B.J. | Eleven Rack | 8 | 11-15-2012 11:02 AM |
Help Please on 02r 96 hookup to 192 io | bryanbassett | Pro Tools TDM Systems (Mac) | 2 | 04-19-2007 07:20 PM |
MTC Hookup | thenchel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 07-21-2006 11:49 AM |
hookup help with m box please | samrisio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 12-27-2004 05:37 PM |
which way is the best hookup? | ddotdeer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 05-03-2001 02:01 PM |
