Old 05-05-2014, 09:32 AM
pcmusicpro pcmusicpro is offline
Default Maximum peak level for a movie comercial?
Hello
I´m mixing a comercial in stereo for a movie theater which complyes with Dolby standart.
I´d like to know what is the recomended maximum peak level I should deliver in the mix.
Thanks, this is my first time mixing for movies.
Old 05-05-2014, 09:39 AM
mr.armadillo mr.armadillo is offline
Default Re: Maximum peak level for a movie comercial?
No such thing. However, you must meet 82 dBleq(m). Then again, if it's stereo, it must be some sort of festival or special thingy because usually a 5.1 is required (Cinema was never (2 channel) stereo), and they probably don't even care.
Old 05-05-2014, 02:13 PM
spoons's Avatar
spoons spoons is offline
You should really try and get a spec. sheet from your client, but for example "Screenvision" ask for a stereo broadcast mix peaking no higher than -20db.
Richard Spooner
Ultimate, S1, Dock, Monterey , MacMini 3.2 Ghz 6-Core i7, 64gb RAM.
www.spoonsound.com
Old 05-05-2014, 02:25 PM
spoons's Avatar
Actually … my spec. sheet is now out of date … "Screenvision' now says stereo broadcast mix peaking at -10dfs
http://www.screenvision.com/wp-conte...Specs_2013.pdf
Richard Spooner
www.spoonsound.com
Old 05-05-2014, 09:19 PM
coaxmw coaxmw is offline
I mixed a cinema spot that was being trafficked through NCM last week. Spec for them was -10 peak and -24lufs. With 5.1 discrete, PL2 or stereo files on a quicktime.
Old 05-08-2014, 02:00 PM
John McDaniel John McDaniel is offline
True stereo; LoRo, fed to Left and Right only in a theater sounds awful.
An LtRt "broadcast" mix or decoded LoRo is a close second, with hyper compressed/limited/EQ'd VO tracks contributing to the awful factor.
j
HTML code is On
Squeezing Maximum Level out of MP3's Hank5 Pro Tools TDM Systems (Mac) 3 05-01-2006 02:00 AM
DVD Peak Level Andy Hay Post - Surround - Video 3 04-17-2005 11:35 AM
maximum quicktime movie length? inscapesound Tips & Tricks 5 09-30-2000 12:18 AM
maximum quicktime movie length inscapesound Post - Surround - Video 2 12-20-1999 11:09 AM
maximum quicktime movie length inscapesound Tips & Tricks 0 12-16-1999 07:28 PM
