Old 05-30-2006, 01:27 AM
kcupper kcupper is offline
Default PT 7.1: Surrounded by BUGS
Hi, anybody come across this nonsense?:
1. Using 5.1 master fader automation to trim noise at track starts puts the software into a tizzy-fit where it outputs what sounds like reverb returns in Lf and Rf channels, and god knows what on other channels...taking the master out of automation read fixes it. Did you guys test this software? I mean....REALLY?
2. Attempting to bounce 5.1 mixes to disk often results in an error message stating that "there is insufficient disk space" for the bounce, and then states the additional space needed for the bounce (e.g. 1.7 GB), even if there is ten or twenty times the space required on the disk (however, this is a cool way [well...not *really*] to find out how big your 5.1 bounce is!). The "fix" is making the bounce a few seconds longer or shorter, so that the software is comfortable. This works but.....come ON! Did you guys test this software? I mean....REALLY?
System:
PowerMac G4 1.25 GHz 1.25 GB RAM
OS 10.4.5 following all of Digi's "suggestions," with fonts, the clock, power saving, software update, permissions (oh brother), etc.
Lacie d2 Firewire drives
PT 7.1cs6
192 Interface, doesn't like any static, even the smallest amount makes it break out in a rash...I think it's REALLY allergic to PT 7...
Waves V5 Surround 360 Plugs, Oxford EQ, Eventide Legacy, etc. they're the latest updates they should all work
THANKS!!
KU
Old 05-30-2006, 03:03 PM
sleadley sleadley is offline
Default Re: PT 7.1: Surrounded by BUGS
No such problems here. Mixing a Film and my music stems (all 5.1) go to master faders then to the Harrison desk. Does not do what you describe. I would follow the fault finding instructions outlined by Digidesign. (Toss prefs etc.)
Simon L.
Plan for the worst, Hope for the Best.
www.trackdown.com.au
Old 05-30-2006, 03:28 PM
minister's Avatar
minister minister is offline
i am not having any of these problems either.
HD|2 ACCELL pt 7.1cs6 6.5 G RAM on a Mac 10.4.3.
so..somthin' aint right. and i KNOW how frustrating it is!
difference between you and me is i do not run Waves and i do not bounce. have you tried creatng an audio track and bussing your master to it? that's what i do and i just finished a 5.1 feature with TONS of tracks and automation and my system to the point of weeping i was eeking out DSP.... print tracks to another drive : no problems. watch film in sync with my printing : good idea.
..i suppose you are using that waves 360º stuff, hunh. could that possibly be the culprit?
does your system do this with EVERY 5.1 session?
also, COCKTAIL and DISK WARRIOR are ALWAYS A good idea!
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
Old 05-31-2006, 01:39 AM
Yeah, it still happens when I try to print the mix within the session.
I went to my shrink today and when I told him I was surrounded by bugs he said, "GET 'EM OFF ME!!"
I'm gonna spray the computer with some RAID, and then maybe trash the preferences....
Thanks, guys, for takin' the time to reply....
KU
Old 05-31-2006, 03:36 AM
MusoPro's Avatar
MusoPro MusoPro is offline
Hi KU,
As far as bouncing to disk I'm sure you are aware you shouldn't bounce to the disk your session is on. That can create all kinds of problems. Is that what you are doing? I am not experiencing the problems your are speaking of.
Best,
Mitch
Best
Mitch
MacPro 2.44 8 Core
Mac OSX 10.10.5
PT 12.7
HD Native
SyncHD I/O
HD I/O
MIDI I/O
C24
Aja LiHi
Surround Setup
Old 05-31-2006, 04:35 PM
Matt Chan Matt Chan is offline
even though the plugins you're using may be compatible, are there leftover 6.xx plugins in your plugins folder? there was something about making sure all of those were removed. we had 6.xx plugins mixed with 7 plugins and had a lot of stability problems when running PT7.
Old 06-08-2006, 05:40 PM
Redmann Redmann is offline
I've heard rumors that Digi is looking into some issues with plug-ins on the master fader. All heresay.
As to the Waves plug-ins. There is a new (unofficial) version of the 360 bundle. It is version 5.0.5_Srnd. I got mine from Digidesign. You could probably get this upgrade through Waves as well.
Old 06-08-2006, 06:14 PM
Craig F Craig F is offline
Are you bouncing to disk or busing to a new track and recording that?
the former is very ill advised
Thank you,
Craig
HTML code is On
11.1.2 on Mountain Lion bugs bugs bugs. command+f, elastic audio, discoloration farmfresh Pro Tools 11 21 05-01-2014 07:21 PM
PT8 bugs murergobben 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 03-24-2009 04:07 PM
Bugs in my box - no, REAL BUGS !!!!!!!!! Mixtrix 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-25-2006 06:33 PM
Old, old bugs Pete Gates Tips & Tricks 2 02-14-2006 09:10 AM
Bugs on 5.3.1 Captain_Pants 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 08-24-2002 11:13 AM
