how do you add a quick fade in fade out on a track
Hey!
I have a simple little jingle on it's own stereo track..and I just want it to fade in from the time it starts and fade out when it gets near it's end. How can I add this simple fade in/fade out configuration in Pro Tools? (I have the digi002R, PT6.4) any help..much appreciated.. thanx, chalin |
Re: how do you add a quick fade in fade out on a track
Create a master fader (File \ New Track then select 1 Stereo Master fader). Go to edit window and in the master fader track, use the pencil tool to draw in your fade in / out. Click at the fade start and end and you'll see PT draw a volume line.You can also use the hand tool to move the start and end of the fade in/out.
If you click the (I'm not sure what it's called) 'link' button - which is the button underneath the three main edit (grabber) tools. That should highlight those three tools at once.
Then mouse over the end of the wave from in the edit window and the tool will change - one of the changes will be a box with a diagonal line through it - click lwft mouse when you see that tool and you'll be dragging a fade on to the waveform. This is the quick way to put in a fade. Otherwise, highlight the area on the waveform you want to add a fade to and press 'ctrl + f' - then follow the options. hope that makes sense , scott
"...I asked you not to tell me that!" |
Yup, you can do that too but I'd still have a master fader so that you can have more control over the start and end points of the fade. Having a master fader is also good if you want to control the 'bounce to disk' level. Either way is cool.
oh awesome..yeah, that was really easy with the three prong button feature. just added
in the fade when i saw the square. nice feature. thanx again |
Digi002R PT2018 Win 10 INTEL Core i7 930, 3.52 Ghz GIGABYTE GA-X58A-UD3R CORSAIR XMS3 12GB 1600Mhz 2 X WD 1TB Caviar Black 64 GB cache MOTU Traveller PT2018 MacBook Pro Mojave 16GB DDR3 |
And when it's at the bottom, and there is an adjoining region, it's a quick cross fade tool.
Automatic fade in and fade out occurring after recording | digicake | macOS | 5 | 11-05-2013 01:07 PM |
I need a quick reminder.(Bussing tracks to Aux for quick fade out) | mexablcknesekid | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-16-2010 09:28 PM |
Fade-In and Fade-Out on Multiple Disjoint Regions | holden | Pro Tools TDM Systems (Mac) | 2 | 11-30-2007 01:22 PM |
How to apply fade-ins and fade-outs on selected regions? | Halstein | Pro Tools TDM Systems (Mac) | 2 | 05-09-2007 03:07 PM |
Why does batch-fade leave out first and last fade? | Frank Kruse | Post - Surround - Video | 5 | 03-08-2006 03:47 PM |
